5v reference, p0641
After that, I tried unplugging all the sensors and reading voltage on the 5v references at the sensors. I was under the impression that if it was a bad sensor then the 5v references would all read 5v since all sensors were unplugged. But still, 2 read 4.8 volts and the rest were around 0.12v.
I did notice on the camshaft position sensor plug, the 5v reference wire had started to show a little copper right where it goes into the plug. The ac bracket that bolts to the oil pan was not bolted to the pan due to some moron forgetting it during a cam swap last year. The 5v reference wire appeared to be touching that metal bracket, so I assumed that was my problem, but after fixing the issue there and clearing the codes, same thing, p0641 and a bunch of sensor codes.
Any body got an easy fix? Trying to figure out where to test voltage at on the pcm side. Can I just check the pins or do I need to go out to the wire while the harness is plugged into the pcm? I'm thinking maybe a bad pcm at this point but I really don't know. Thanks for any feedback!
sounds like you you still have a short, or the pcm output is bad.
unplug the sensor and harness from the pcm and check continuity to ground.
If it's still there, you know it's the harness. And you'll have a spare PCM if you ever brick yours and/or you can turn around and sell it for what you bought it for. But it's a good way to eliminate one issue.
