01 camaro ss, Codes and Lights
Old Sep 20, 2017 | 08:46 PM
mhorn0817's Avatar
Default 01 camaro ss, Codes and Lights
Picked up a 01 camaro ss m6 tonight. Had a bunch of codes and lights on hoping you guys can help me start somewhere and narrow them down.
Lights on are...
"abs inop"
"asr off"
"airbag"
Codes that are shown are...
Engine
P0102. Mass air flow signal low
P0103. Mass air flow signal high
P0121. TP sensor or APP sensor 1 problem
P0155. 02 sensor bank 2 sensor 1
Abs
C0040. Right Front or Any wheel sensor circuit fault
C0240. Pcm traction control not allowed
Airbag
B1001. Option configuration error
U1040. Loss of ebcm/ebtcm communication
Car was just sitting and idling for about 10 minutes and then randomly idled up to 1500rpms and would not come back down.
car has...
Long tubes with erg, dynomax catback
comp xer281 cam
slp lid
z06 maf
Rebuilt rear with auborn posi and 410s
Any help and guidence and where to start would be great.
Old Sep 20, 2017 | 10:31 PM
2xLS1's Avatar
For the engine codes, buy HP Tuners so you have the ability to see the calibration in the PCM and have the ability to data log real time data while running. Since the car is modded with a cam it has probably been tuned and it could be either a good tune or crap. More than likely crap for the way it is acting.
Old Sep 21, 2017 | 10:50 AM
mhorn0817's Avatar
Nah, no sense in buying hptuners if i have to get it retuned anyway.
PO said he added z06 maf and never got a retune so im assuming thats the maf codes...obviously needs a 02 sensor and guessing tps sensor since it has a code and randomly idles high
Gonna throw a new hub and sensor on front right and hope it take a care of abs and asr codes and lights.
Not sure on the airbag light or code though.
Old Sep 21, 2017 | 12:17 PM
2xLS1's Avatar
Then why ask for guidance? HP Tuners is for diagnosing and retuning it.
Old Sep 24, 2017 | 05:05 PM
mhorn0817's Avatar
Replaced the TPS sensor and did the quick relearn procedure and still have code p0121.
Replaced both front hubs with wheel sensors and abs and trac light still on. I did live data with my scanner and the right front is not measureig any data, so im assuming a wiring issue?
Old Sep 28, 2017 | 08:10 PM
mhorn0817's Avatar
Found a damaged wire on right front speed sensor harness. I repaired the harness and the ABS INOP light went out and the speed sensor code went out. BUT, My traction light is still on with code c0240. What could that be
Old Sep 28, 2017 | 11:23 PM
youguessit's Avatar
abs module
or wiring... including plugs. quick check the connection between the abs module and the wiring harness... see if water got in.
Old Oct 12, 2017 | 04:30 PM
mhorn0817's Avatar
Would a bad abs module only effect traction control?
