Calling all Holley Dominator / HP F-Bodies
Has anyone came up with a way to run factory gauges with these Holley setups? I'd imagine it's probably like the guys running the MS3 systems and I believe they are splicing into the factory ecu??
What's the benefit of running these Holley's over the factory ecu? I'm going to get my Nitrous setup someday when funds replenish and I know that running an aftermarket setup would be beneficial. Do you guys gain a lot in tuning? Or increased reliability Driving?
I also have the Holley dash so one screen displays Speed/RPM/Oil pressure /Coolant Temp/Oil Temp/Trans Temp/Volts/Boost/AIT's/AFR/Flex fuel and it can monitor anything I want/need it to, It can also be configured as a virtual switch panel.
Basically if you want to control/monitor something the Holley will do it.
You can configure multiple fail safes so you run to hot/no oil pressure/over boost and so on it can be configured to pull timing/shut down whatever you want it to do.
I am installing HP EFI at the moment. All of the connectors on the passenger side can be unplugged. I am currently tracing all the wires back to the fuse panel and deleting what I don't need. Just wanted to confirm what you had said.
