Android/Elm327 Pcm Flash App (LS Droid Read only released)
Old Apr 21, 2018 | 02:50 PM
  #161
PeteS160's Avatar
OBD Link LX confirmed to be 100% working
Given that a lot of the cheaper devices do not have the buffer capacity I'm now looking into adding USB-OTG support. I have been able to get the OBDLink Sx USB cable to work via a Micro Usb to USB A adapter in a serial terminal with Android 6.0 and up. It's going to take a few days to try and get my app working with the phones USB port but it's very doable and will open up a lot more possibilities for future development.
Old Apr 21, 2018 | 04:02 PM
  #162
toplessHO's Avatar
Originally Posted by PeteS160
It can not change the serial number, The buffer in the device is too small, Ive tried every way possible even going as far as doing the serial number one digit at a time but by the time the address to load the serial at in the pcm is set the buffer is full.
Damn,bought one(BAFX) with recommendation here,havent even got it outta box and its already outdated
Old Apr 25, 2018 | 12:19 AM
  #163
PeteS160's Avatar
Send me a PM if you'd like to try the app out. Currently this is only 100% working for the 99-02 512K pcm's and requires either an OBDLINK Mx/Lx or genuine Elm327. The BaFX will only change the Vin number and is NOT does NOT use a genuine Elm chip . On the 03-07 1mb pcm's this will only change the vin number.
Old Apr 25, 2018 | 12:38 AM
  #164
JoeNova's Avatar
Restricted User
I can't send PMs. Send me an email and tell me where to get the app.
joefields1987@gmail.com
I already have an OBDlink ready to go.
Old Apr 25, 2018 | 05:31 AM
  #165
fst100's Avatar
Pete, sent you a pm
Old Apr 27, 2018 | 01:06 AM
  #166
PeteS160's Avatar
Instructions on what is done on the pcm circuit board can be found HERE
With just a couple of minutes, a short piece of wire and the latest version of LS Droid..... Tuner locked PCM's are now a thing of the past (P01 Pcm's only)
Old Apr 27, 2018 | 03:23 PM
  #167
toplessHO's Avatar
https://youtu.be/11GoY_rElKc
wow
just oh wow
tight up those purse strings boys
Old Apr 27, 2018 | 03:53 PM
  #168
1FastBrick's Avatar
Nice, Thanks for the tip! Will save a lot of hassle for many people.
Old Apr 27, 2018 | 07:41 PM
  #169
OK, I realize what's happening in this thread is BIG. Even revolutionary. But would somebody put into layman's language what it means as far as tuning, accessing the PCM, etc., etc.
Start another thread if need be.
Old Apr 27, 2018 | 08:11 PM
  #170
toplessHO's Avatar
have you read both threads on this in entirety?
if so go back and re read.
open source programming....
Old Apr 28, 2018 | 07:23 PM
  #171
truckdoug's Avatar
it means **** HP tuners we're gonna have our own ****
with hookers....and blackjack!
Old Apr 28, 2018 | 08:46 PM
  #172
Well, I can relate to that! lol
Old Apr 30, 2018 | 09:59 PM
  #173
NSFW's Avatar
The immediate goals here are:
1) read the entire memory from your PCM and save it to a file
2) write the file to your PCM
In between those two things, you've got a file that you can modify with software like TunerPro or other tools. It'll take some additional work to create definitions so that those tools can really be used for tuning, but apparently there's a pretty complete definition already for a 2001 LS1 car (I forgot which), and that will give us a big head start in getting other cars supported.
The other thing I'm really looking forward to is reverse-engineering the code (not just the data) and then tweaking it to do cool stuff - different fueling strategies, 2-step rev limiters, rev-matched downshifts, valet mode, etc, etc. Subarus and Mitsubishi Evos have a bunch of cool stuff like that, and it's time the GM V8 universe got caught up.
Old Apr 30, 2018 | 10:28 PM
  #174
PeteS160's Avatar
Awwww I was saving all of that for the grand finally.....
For those that haven't cough on yet this is being developed in in parallel with what's going on in THIS THREAD
Ideally.... the Pc version and the Android version will be able to use the EXACT SAME DEVICES. The Android version will not have the exact same capabilities and like wise the PC version will also not do all the same things the Android version does.They each have a time and place and since they will use the same devices there is ZERO draw back to this.
What makes it even better is these will both be 100% free ! ! ! ! ! !
Alright....now you need to calm down
Spoiler!
Old Apr 30, 2018 | 11:11 PM
  #175
PeteS160 and NSFW-
Thank you so much for clarifying it to a degree where I THINK I know what you're getting at! I think.....lol
Anyway I hope it becomes the revolutionary tool it should be.
Old May 2, 2018 | 10:33 PM
  #176
PeteS160's Avatar
HUSTON.....Your not gonna believe this but we're seeing what looks like an LS Pcm's .bin file.....
But it's only an Android phone with a cheap Bluetooth device....what......how......it can't be.......it's reading an LS Pcm's flash chip and saving the data as a .BIN file just like commercial tools.....that's......THAT'S IMPOSSIBLE ! ! !
Spoiler!
Old May 2, 2018 | 11:02 PM
  #177
Calm down Clark.... EVERYBODY knows your not really Superman.....
Old May 3, 2018 | 12:03 AM
  #178
NSFW's Avatar
Excellent choice of music for this episode. LOL. Bravo.
Old May 4, 2018 | 01:58 AM
  #179
PeteS160's Avatar
Was able to get a complete read out from a 411 tonight in 4x mode.......this thing chews threw blocks so fast it's almost scary ! ! !
I even over shot the read address by a couple hundred bytes with out an error.
I never expected to see anything even close to this type of performance.......
Big Shout out to Antus@pcmhacking for his amazing work with the Allpro firmware and an amazing flash kernel to boot
Old May 18, 2018 | 08:49 PM
  #180
WD10's Avatar
Hi Pete,
The app looks amazing!!
I sent you a PM
