0411 PCM to 00 SS
In HPT controls I can not even get them to come on.
Relays are good, fuse is good.
As far as I know, all segments were swapped when the tune was done. Is there anything you can think of for me to check in the tune?'
Any testing I can do?
If everything is wired correctly hptuners controls should turn them on and off.
I may have damaged the ext sensor could that contribute? When putting it on I heard a click like I may have cracked it. My temp gauge has never worked even before this issue.
I have an 0411 pcm that's Not stock but the wiring is all stock. No external relays wired.
With instructions I can wire about anything.
I just tried to unplug the ect sensor. The fans still didn't come on.
which wire will I need to ground from the fan to test the fans and which wires should pulse a ground from the ecm?
for low and high speed.
forgive me if I'm not asking the right questions. Thanks for all of your time guys.
I'll post times when I get this fixed.
On a 4 prong relay u have your battery #30.
U have fan power #87
One of the 2 left over will pcm ground. The other will be a jumped hot from battery or ign 12v.
These 2 prongs dont really matter orientation they can be visversa. Just find pcm ground trigger and jump it to ground. Fans should turn on.
C3.....Battery Hot
B3.....Battery Hot
B1.....Ground Trigger from PCM (Low Speed) Pin 42 of C1.
C1.....Output to Left Cooling Fan, Should test as a ground with #3 Relay in place. Applying B+ to this pin should turn BOTH fans on a half speed.
**IF the Left or Right Cooling Fan is bad (Open), or a Bad Connection at the fans.......Low Speed operation will not work! **
Cooling Fan #2
C6.....Battery Hot
C4.....Battery Hot
B4.....Ground Trigger from PCM (High Speed) Pin 33 of C2.
B6.....Output to Right Cooling Fan, Should test as a ground, Applying B+ to this pin should turn on the Right Cooling at Full Speed.
Cooling Fan Relay #3.....MUST use a relay with a 87A Post (5 pin Relay)at this location!!!!!!
B9.....Should test as a ground through the Right Cooling Fan, Applying B+ to this pin should turn on the Right Cooling Fan at Full Speed.
B8.....Battery Hot
C8.....Open Circuit, Should have an OHM reading to C1 of Cooling Fan Relay #1 (Whatever the resistance is of the Left Cooling Fan Motor)
B10....Ground.
C10....Ground Trigger from PCM (High Speed) Pin 33 of C2.
C3.....Battery Hot
B3.....Battery Hot
Cooling Fan #2
C6.....Battery Hot
C4.....Battery Hot
B8.....Battery Hot
B10....Ground.
After just testing to see if the fans work at all.
When I just cut that off another car I looked under it and noticed those blades add power to the RELAYS!!!
When I get down next weekend I will tap into those metal blades and give power from the universal distribution post that I installed. Ill try to get a pic up to show what im talking about later. But that distribution post with the red cap broke OFF on my car. I just mounted one above it on the wheel weld. I wish I had saw this before because I have done quite a bit not seeing the obvious.
How hard would it be to replace that entire fuse box with the post?
For now if jumping power to those works...I appreciate everyone that took time to help me diagnose so I feel its only fair to post my progress. Thanks guys.... after I get back to the car next week. I hope to be able to post success!!
