hunting down p0301 cause ...
... ok so no probs with the car at all running fine UNTIL i do a plug & wire change. i then get p0301. have cleared it multiple times it's the only code that comes back. ok so i changed out ALL the new spark plugs & wires with MORE NEW spark plugs & wires, & bought/installed a new coil pack for cylinder 1 to no avail - same code/results ___ swapped out 3 different plugs & wires with both the new and old coil pack installed on cylinder 1 with SAME results/p0301.
Acts exactly as a misfiring car would, bad rough idle that gets worse/loses more power in either drive or reverse/car shakes enough for you to know it's misfiring. i have also cleaned the maf & tb off car very well with maf & tb specific cleaners.
.... ok so a friend suggested bad injector, but remember this has only happened seemingly due to the spark plug & wire change. ANY input/ideas ?
Check your grounds too, especially the ones on the backside of the d/s head.
