p59 flex fuel not reading alcohol content
Old 03-01-2018, 10:32 PM
truckdoug's Avatar
Default p59 flex fuel not reading alcohol content
2004 dbc van OS with flex and 80e licensed to a 2004 gto p59 pcm
all the tables are there and visible, editable
I can add alcohol composition in the scanner channels but it never reads anything
triple checked my pin out. Vout is pin 56 C1 middle is ground, Vcc is 12v keyed. new connector, new sensors (2 now)
and still nothing. immersed in e100, nothing. e15 nothing. e85.....nothing.
here's my tune. i'll paypal 50 bucks to the first guy who solves it.
I'm stumped.
File Type: hpt
Old 03-02-2018, 08:21 AM
jchevy's Avatar
I fought with this on my van pcm. I had to flash it with a factory enabled flex fuel file from a tahoe. I dont beleive the GTO was flex fuel compatabe stock.
The base tune file has to be a factory enabled flex fuel tune. It doesnt matter that the PCM is compatable.
Old 03-02-2018, 09:05 AM
LSX Power Tuning's Avatar
I agree, we always start with a factory flex fuel suburban or tahoe then change what we need to.
Old 03-02-2018, 10:11 AM
truckdoug's Avatar
I'm unclear. Are you saying I should start with a pcm that has flex, dbc, 80e already license that and I'll be good?
I was under the impression I could flash the flex/dbc/80e OS to any compatible p59 with the IAC driver.
The stock gto tune did have flex tables iirc, they were greyed out though.
Subeone, where are you...you're my only hope! 😄
Old 03-02-2018, 10:17 AM
Received 3,027 Likes on 2,357 Posts
Love the Star Wars reference....
Old 03-02-2018, 10:25 AM
jchevy's Avatar
I thought the same thing as you and could not figure out why i could not get it to work...i even bought a second sensor thinking the first one was bad.
I flashed it with a tune from a tahoe that was a flext fuel vehicle off the show room floor and it worked after that.
I could see all the tables and enable it in the tune on the van pcm but it wasnt actually enabling it.
Old 03-02-2018, 01:20 PM
truckdoug's Avatar
Word I'll blow some credits at it.
Do you have the .hpt file by any chance?
Old 03-02-2018, 02:55 PM
I have never tried it with a gto pcm, just a truck P59 then I use tis2web to flash in a stock tahoe or suburban flex fuel tune into the pcm. I then read that out in hpt or efi and build the tune. You can just write entire with hpt but I prefer tis2web when changing complete tunes like that.
Old 03-04-2018, 01:56 AM
roughneck427's Avatar
HPT is missing a few tables. Pic on the left is a FF compatible ECM but no parameters filled. The one on the right is a factory L59 calibration. And below the only 3 tables and master switch with HPT that is visible. I cant download the file for some reason repost it with drop box or something and ill fix it.
Attached Thumbnails p59 flex fuel not reading alcohol content-tcbefore.jpg   p59 flex fuel not reading alcohol content-tcchanged.jpg
Old 03-04-2018, 08:04 AM
jchevy's Avatar
I just pulled a file out of the repository on the hptuners site. I can send it to you later if you havent found one.
Old 03-04-2018, 09:47 AM
truckdoug's Avatar
yeah please send it to me or post it here.
i verified with Subeone i'm using the wrong OS....again lol.
Old 03-04-2018, 09:48 AM
truckdoug's Avatar
do you have google drive?
https://drive.google.com/open?id=1Vc...MKzPVgsRcvhvbL
Old 03-04-2018, 10:06 AM
Do you have the file before you upgraded it to 3bar?
Old 03-04-2018, 11:29 AM
truckdoug's Avatar
Ill have to dig around, but I think so
Old 03-04-2018, 11:42 AM
I used the VIN and pulled a bone stock file off SPS, all i did was enable the FF with the software i use and read back out with HPT.
File Type: hpt
Old 03-04-2018, 12:08 PM
truckdoug's Avatar
rad dude! i'll go flash it now and see if i can get an alky %
i did find the OG OS both for the pcm and the 04 van i built the current tune on
https://drive.google.com/open?id=11M...gffxVa-2mxlH72
https://drive.google.com/open?id=1F6...m-vT-9MUM2VLvA
Old 03-04-2018, 12:10 PM
truckdoug's Avatar
yeah it looks like the file hosting feature on this site is down right now. could you email that .hpt to me? pm'd you my email
Old 03-04-2018, 12:42 PM
i emailed it to you
Old 03-04-2018, 12:54 PM
truckdoug's Avatar
YESSS it WORKS thank you so much man! I am not easily frustrated but that had me stumped.
Old 03-04-2018, 12:56 PM
Awesome! i had had same issue same OS I had found like I had mentioned HPT does not map out all the tables to enable a non factory FF calibration even though it's capable.
