ECU Help
Old Apr 24, 2018 | 01:48 PM
All Pontiac WS6's Avatar
Default ECU Help
Hey guys,
I did not get the ECU when I bought my 6.0.
What should I get a ECU from?
Here is some of my info....
2003 S10 automatic was a 4.3.
Going in is a 2003-2004 6.0
I will be using a TBSS intake with the TBSS injectors.
It will have a 90mm DBC TB.
Thanks, David
Old Apr 25, 2018 | 02:27 AM
NSFW's Avatar
If you know the part number for the PCM that came in the vehicle that your 6.0 came from, try searching for that part number on ebay. Or try a junkyard.
I bought a used 12200411 for my 02 Corvette from a seller named spareecm (I'd post a link but that might break the rules). It was about $90 and I heard later that you can get them for half that at junkyards, but it's clean and it works and I didn't have to pull it out of a wrecked car (in the snow, uphill both ways). Mine is expecting a 24x wheel on the crank and it's DBW, but if you know the part number and the vehicle type, I suspect you could find one that would suit your setup.
BTW, coming from Subaru I'd call it an ECU too, but GM calls it a "powertrain control module" or PCM. In auto cars it controls the transmission as well as the engine.
Old Apr 25, 2018 | 08:15 AM
Thanks for the info.
Old Apr 25, 2018 | 11:00 PM
brandon6.0's Avatar
Yes get a 2002 silverado 411 pcm. If u need any bench tuning hit me up.
Old Apr 25, 2018 | 11:01 PM
1FastBrick's Avatar
An 03 S10 will already have a 411 PCM in it. And you can have it reprogramed to run the 6L
Old Apr 26, 2018 | 04:20 AM
My S10 has a ....SERV.....12576105
HDW .....12570558
Old Apr 26, 2018 | 11:56 AM
PeteS160's Avatar
HDW .....12570558
Are you 100% sure the last digit is a 5 and not a 6? If it's 12576106 then the pcm will work with drive by cable or wire. The only difference you'll notice between say the 411 and a pcm like 12576106 is going to be the O2 sensors and wiring for the sensors. On the 03+ style pcm's each sensors ground comes directly from the PCM where the 0411 style pcm use's a common engine grounding point.
Unless your planning to run boost the 03+ pcm is superior but much less common since there are so many part numbers and not all of them will work with drive by cable throttle so people tend to fall back to the 411 since they know it works.
Old Apr 26, 2018 | 01:46 PM
1FastBrick's Avatar
HDW .....12570558
Ok, it was just the 01-02 that had the 12200411
Looks like 12576105 or 12576106 may have been an 03 only thing. But regardless if it was a drive by cable set up, it can be reprogrammed to run your swap.
I don't see any one listing an 12576105 service number though for an S10 or blazer.
Are the PCM connectors Blue and Green or Blue and Red???
Old Apr 26, 2018 | 07:55 PM
I have not taken the cables off yet. I am still driving it, still a v6 at the moment.
Old Apr 26, 2018 | 09:15 PM
LSX Power Tuning's Avatar
We keep pcm's in stock and can reprogram them for whatever you need.
Old May 13, 2018 | 09:56 PM
Default Ecu
Is this what I need?
Old May 14, 2018 | 11:48 AM
yes that will work
