Main Ve question
What happens when you increase or decrease a number in the cell?
I know its part of the Fuel/ air mixture, but when you increase the number in a cell , is it adding fuel or taking it away?
the numbers in there relate to a pulsewidth commanded of the injector solenoid.
bigger the number the more pulsewidth is commanded and the more fuel you have
smaller the number the less pulsewidth is commanded and the less fuel you have.
the VE numbers don't relate directly to anything theyre just a number. make it bigger youre adding fuel. make it smaller youre removing fuel
The VE table is the cylinder air fill (regardless of fueling) at each cell.
The various fueling tables (Stoich AFR, OLFA, PE, PPM, COTP) specify the ratio of fuel to air that the PCM applies to the cylinder air fill.
Keep air and fuel separate.
Same with MAF table... it gives you the mass of air per second, PCM calculates cylinder air fill from this, then applies fueling on top of this.
However, it uses back calculation to add fuel (which you don't see). So you tune with a wideband... when you're too rich (compared to Stoich or your PE desired EQ ratio), you don't have enough air in the VE table and you increase it by the delta between Stoich or your PE desired ratio. Lean is opposite. This is why Lambda works well, it converts the stoich A/F to a number... 1 is Lambda. And everything is a ratio based off that. So your PE should be EQ ratio of 1.18 or so and etc.
But that's getting too deep. If you measure dynamic airflow in the VCM scanner, you can see your airflow in g/sec. Which is just reading from the VE table. So once it's tuned, you know about how much airflow your engine is ingesting. For an SBE LS1 with H/C/I anything in the 400g/sec and over mark is making very good power.
Note: EFI Live allows you to view the VE table in g/sec vs. the somewhat useless percentage in HPT.
