Hptuner failure & IAC
Unit used less than 10 times.
Long story short I have an mpvi2 that is on way back to hptuners. Fairly certain unit is defective. However here is what happened. The unit was having issues connecting. I figured it was my side of things so I uninstalled and re installed software.
I reflashed car after making some adjustments to throttle cracker and as it was writing and doing its thing I washed the car. I open the door and it was done. I start the car and immediate very high idle. Like entire brake booster hose was off. 3000rpm. I was like oh man. I pulled car into garage and thought maybe this unit is going bad. I tried to do a reflash but unchecked the high speed write. It started to erase and failed mid erase and car wouldn’t start. After about a dozen controller unlocker errors I wound up disconnecting the battery and opening vcm editor from original folder and it finally reflashed. The high idle is stuck there and I start trouble shooting this. Iac valve is fully retracted and it will do nothing but vibrate when I command different counts in the scanner. Even a new ac delco will do nothing. If I manually pull out iac valve and disconnect and reinstall the car idles pretty close to set rpm. I’m almost certain it’s not a mechanical issue but a software/electronic fault. I hooked up the mpvi2 to laptop today and it won’t even recognize. In the mean time has anyone had this happen? Should I go ripping into the iac harness or do you think a clean write with a good tuner will fix this? This is incredibly frustrating and stressful so I guess I’m just fishing for someone else’s experiences. Also considered bad pcm or iac drivers? Connectors on pcm harness are red/blue.
I got this from the sloppy site:
IAC Relearn Procedure
If you are having idle issue you may need to reset your Idle Air Control (IAC) and
TPS, do this before you start drilling holes in your throttle body (TB) blade. I have
used this procedure on some huge cammed cars and it worked.
1) Monitor your IAC, Idle Speed, throttle position voltage and your throttle position %.
2) With the key in the ON position, adjust your TB set screw until your throttle position
is 2%.
3) Turn your key to the OFF position.
4) Unplug your Throttle Position Sensor (TPS) and IAC.
5) Turn your key to the ON position for a few seconds, and then OFF again.
6) Plug in the TPS and IAC and then turn your key to the ON position and restart
logging. Your throttle position will now be reset to 0 degrees and about .45-.55 volts.
7) Start your engine, your IAC should be 40-60 for a cammed engine.
if you are not at your desired IAC position redo the above procedures in smaller
increments.
I think when your write failed, your iac home was set incorrectly for whatever reason.
It *seems* like the new MVPI2 is writing back data into the wrong places. Different OS's vary in length and store data in different places in the binary code itself.
