HELP!!! Holley EFI wiring solution.
Does anyone have a wiring solution or advice on the matter? I already know that the dominator will have to share the signal wire from the crank sensor with the stock ECU for the tachometer to work.
Anyone-successfully-tie-into-a-stock-cluster
You might have to choose between going back to the stock ECU or losing some dash function with the Dominator. Myself I use the 7" Holley dash for everything display wise.
– and thanks LL, the guy the 2nd post looks like he has done it so again I know it's possible.
