Bad map sensor readings
Old Aug 22, 2018 | 06:24 PM
Crysis's Avatar
Default Bad map sensor readings
Hello I have a gen 3 5.3 turbo cam on e85. Ive been having a problem with my map sensor readings its off a 2005 cobalt ss what I did was get the data a 05 cobalt ss and enter it into my tune and it seems with the slightest throttle kpa is going through the roof any ideas what this could be??
File Type: hpt
File Type: hpl
Old Aug 23, 2018 | 08:01 PM
Crysis's Avatar
Any Ideas???? what map sensor are you guys running and with what settings I might try and just get another one
Old Aug 24, 2018 | 10:43 AM
Luke19901's Avatar
2 problems, your MAP data is wrong as you're logging 133KPA with key on engine off. This should be 100KPA unless you're in an area with lower barometric pressure.
plus, your IAT sensor is open circuit. that will through air mass and fueling calculations off by a mile.
if you have a 2 bar Delphi sensor set linear to 200KPA and off set to 10.33KPA. use the scanner to make sure the MAP records 100KPA with key on engine off.
do that plus install an IAT sensor and use the scanner to check its reporting accurate data and you'll be good to go
Old Aug 24, 2018 | 11:11 AM
Crysis's Avatar
Yeah I was doing some testing so I had the iat unplugged, and no I said it was from a 05 Cobalt ss so I've tried the stock settings and u also tried .200 and 10.33 neither worked. I'm not too sure but I'm at 5000 fr altitude so what should be the key on engine off reading
Old Aug 24, 2018 | 11:19 AM
Luke19901's Avatar
internet says 84KPA barometric pressure.
what map sensor do you have?
Old Aug 24, 2018 | 03:45 PM
Crysis's Avatar
Its the stock map sensor from a 05 cobalt ss I already tried using the settings from a stock 05 chevy cobalt ss
Old Aug 24, 2018 | 03:49 PM
Crysis's Avatar
I'm thinking of just running another map sensor, whats a good known 3 bar map sensor 3ppl run
Old Aug 25, 2018 | 12:32 AM
Compsystems's Avatar
Lets try this again....
Whats the PN on your map sensor. you probably dont have what you think it is.
Old Aug 25, 2018 | 01:20 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I thought the Cobalt was a 2.5bar sensor. If you input data from a 2bar sensor it will be incorrect.
Old Aug 25, 2018 | 11:19 AM
Crysis's Avatar
I bought it from a parts store so it should be for what I asked, and I input the data from the same year make and model
