no flex fuel spark advance adder on 3 bar p59
for some reason my flex fuel spark adder table is not adding to my total advance.
is there another place that I need to enable or look at?
the table i'm speaking of is under Engine > Spark> Advance> Spark Correction>Misc> Flex
I'm logging Timing advance, base advance and flex advance and NEVER see any added spark from the flex table.
*I did have problems with the flex fuel not being enabled in my initial OS, and a helpful forum member turned in on with tunercats---maybe the same issue here?
huh fancy that. downloaded vcm suite v4.0 and I can see that table now.
not entirely sure how that table works, it appears to be a multiplier for the spark adder table, with the percentage of spark added based on MAP
in which case I want it at 1.0 across the board right?
