Handheld Turner for my situation?
So I'm a huge noob to tuning I'm not going to lie, but I've been reading up lately on all the handheld tuners. I have just finished a 5.3 swap into a 1981 firebird, and it has a dorman intake, a different cam and full exhaust, I talked to a local shop about a tune and they told me close to $1000. I expected somewhere around that price, but what if next year I switch the head, which I plan on doing eventually, is it going to cost another $1000? Is there a handheld I could get to make the car more driveable and run a little better until I get all get these bigger upgrades done. Fyi, the cars driveability is a little rough right now, it doesn't like to stop, lol, and almost dies when in gear while stopped. I appreciate any help, thanks.
So let's say I stay with this setup for a couple years and then change the heads and maybe port or change the intake later, what would you recommend I do. Right now it's no fun to drive, lol.
Get a professional tune now that can become the basis of your tune later when you change things. Just be advised, tuning has a steep learning curve and carries some risk of destroying your motor if you run your fuel-air mixtures too lean and too hot - can melt a piston top.
Rick
Rick
Rick
Rick
true it's a steep learning curve, but for me it's become the most enjoyable part of swapping motors and boosting them
make small changes and then observe the results. make notes. ask questions. be patient. double check your work---read plugs etc
have I hurt motors? yes I have. Will you? It's possible if you get greedy enough with timing
right now even with the problems HP Tuners is having with the new interface I still think it's the best buy
a handheld is not going to work for that swap/setup... you need to take it to a shop to get tuned on a dyno...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Absolutely any time a handheld tuner is good enough, you are wasting money. It may or may not give you any gains, and it may or may not compromise reliability. You just have no way of knowing what you may get. You could lose power and drivability just as easily as you could gain it, because their program is nothing but a guess designed to grab your cash.
