NEWBIE and need help with A/C idle
I am new to the site and need some help with an issue I have regarding the A/C and idle. I recently put a LS3 gm525 with 4L65E into a 72 chevelle. I have E38 and T42 controllers and a PSI harness. The problem is when the A/C is turned on the idle drops and almost stalls. What causes this? and What can I do to prevent this from happening? Do I need a larger alternator? The heater works fine with no changes in RPM at idle.
In Gear AC off 850 850 850 825 775 700 700 700 650 559.9609375 550 550 550 550 550 550
In Gear AC on 850 850 850 825 775 700 700 700 650 559.9609375 550 550 550 550 550 550
P/N AC off 900 900 900 875 875 875 875 725 675 650 650 650 650 650 650 650
P/N AC on 900 900 900 875 875 875 875 725 675 650 650 650 650 650 650 650
Here is the table to try and adjust your target idle speed for Ac in gear on and park/neutral idle speed.AC on.
