Hp tuner without pro
Old Jan 13, 2019 | 07:45 PM
epfatboy's Avatar
Default Hp tuner without pro
I have a basic HP Tuner MPVI, wondering if I should use the AC high pressure lead to monitor AFR or if I should find a used MPVI PRO....
Not sure how big of a hassle using the AC wire is?
Old Jan 14, 2019 | 02:33 AM
Lethalwx69's Avatar
If your wideband has a serial out, you could use that.
Old Jan 14, 2019 | 06:28 AM
epfatboy's Avatar
I have a Innovate MTX-L.so I have a serial port and 2 outputs.
I'd like to have the AFR info displayed thru the HP Scanner software. Pretty sure I'd need to wire the gauge output to an ECM input. I have seen a few posts where folks use the AC pressure wire and configure this pid to report AFR.
Just wanted to hear from some folks on this option versus having MPVI Pro
Old Jan 14, 2019 | 06:34 AM
JoeNova's Avatar
Restricted User
If you only use it for your own car, standard.
If you use it to tune other peoples' cars, Pro.
Old Jan 14, 2019 | 02:43 PM
LSX Power Tuning's Avatar
If your wideband has serial out, you connect it to your laptop through a serial to usb converter and plug it into a second usb port and your wideband will be in hpt.
Old Jan 14, 2019 | 05:41 PM
epfatboy's Avatar
Okay, that is too easy so I googled it and here we go... many more just like this writeup as well.
https://forum.hptuners.com/showthrea...gh-Serial-port
So I guess I'm curious why anyone would want a PRO and why there are so many write ups to use an existing wire like AC pressure?
Old Jan 14, 2019 | 06:33 PM
We have been using serial widebands since mid 2000's with efi live and last couple years with hp tuners when they released it. We wont even do email or remote tunes any longer with egr or ac connected widebands.
Not all widebands have serial out, the pro also allow you log fuel pressure, bottle pressure or anything 0-5v for the most part. The pro will also unlock other features in the future.
Old Jan 18, 2019 | 12:18 PM
Suncc49's Avatar
The old pro could do standalone datalogging with no laptop open, which was nice for many tracks that wouldn't allow people to do it... also you can run temp wiring for analog inputs while tuning or permanent ones for wideband / pressure transducer of your own choice...
Old Jan 18, 2019 | 03:33 PM
llafro's Avatar
I'm using the AC pressure sensor PID to input the wideband data on my car. I have a single pole, double throw switch wired into the AC pressure wiring that allows it to either function as normal or to become the wideband input. It takes a bit of calculation to get it to work. I have a math parameter set up that will take the voltage signal from the wideband and convert it into AFR, as well as a wideband error configuration that shows how far off things are from the PCM's commanded AFR.
