98' to 99' and up PCM question
My situation is a little different, my 98' Z28 is a roller, and has no harness. I have found a company that offers a 98' to 02' PCM swap kit which includes the following: Proper setup for 98 fuel gauges, setup for selected transmission, rear end ratio, tire size, and coded to VIN.
My thought is because the PCM will be coded to my VIN, I shouldn't have to worry about VATS delete until my "real" tune, and I shouldn't have to repin the harness because I can just source a 99+ harness from a Tahoe? Does that sound correct, anything else to worry about? I need a PCM and harness either way, this seems like a decent option to end up with an 0411 PCM without the headache in a 98'.
Edit:
Continued to search it appears any 99+ LS engine harness will work with the PCM since these harnesses used 411 PCM, however, the one issue I have uncovered so far is that the 98' cluster displays the coolant temp directly from the sensor which is a three wire sensor and the 99+ harness is for a 2 wire sensor so at minimum the sensor needs to be upgraded. Still tryin to figure out how to work around to display the coolant temp on the cluster.
With enough re-pinning and re-wiring you can make anything work in theory, if its worth it would be the question, essentially you would be rebuilding the whole harness.
LSX Power Tuning confirmed that the f-body body harness has three connectors and the truck engine harness won't connect. However, from searching it seems like people have used 99+ f-body engine harness and the only issue that I have found was that the 98' uses a three wire coolant temp sensor, and the 99+ use a two wire. I haven't seen anything stating you have to upgrade body harness and cluster, only that you have to have the correct fuel segment tables for the fuel gauge to read the fuel level.
