BTR Nitrous Cam Tuning
Old Mar 5, 2019 | 05:37 AM
02fbodylsx's Avatar
Default BTR Nitrous Cam Tuning
I have recently installed a BTR Nitrous Cam and 60lb injectors on my car along with Trick Flow heads. Previously I had 36lb injectors and Texas Speed tsunami cam. Having trouble getting the car to start it will turn over and stutter like it is trying to start but overall just fail, looking for advice on how to get the motor to turn over.
all grounds and sensors are good as I'm am throwing no codes. and double checked again when the issue started. thanks
Old Mar 5, 2019 | 06:29 AM
JoeNova's Avatar
Restricted User
Have you updated the injector data in the PCM to match the new 60 lbers?
Old Mar 5, 2019 | 07:40 AM
02fbodylsx's Avatar
I was able to adjust the injector flow rate vs kpa is this correct to match the new injectors.
Old Mar 5, 2019 | 03:41 PM
02fbodylsx's Avatar
Bump..
Old Mar 6, 2019 | 10:17 AM
LSX Power Tuning's Avatar
If it was tuned for your old cam it should be close enough to fire atleast if you got the injector data correct for the 60's. You have to change more than just the flow rate however.
Old Mar 6, 2019 | 04:08 PM
02fbodylsx's Avatar
What else would I have to change that's all I have for fuel injector options
Old Mar 6, 2019 | 04:25 PM
02fbodylsx's Avatar
Real new at this lol😂
Old Mar 7, 2019 | 11:07 AM
rel3rd's Avatar
Are they Siemens Deka 60#ers?
If so, I can email you copy of my tune, which has the right injector data...just PM me an email address
ASSUMING YOU ARE USING HPTUNERS?
Old Mar 7, 2019 | 11:49 AM
02fbodylsx's Avatar
Yes this is all o hp tuners
Old Mar 7, 2019 | 01:36 PM
rel3rd's Avatar
OK...sent you an email.
Please report back whether it helps or doesn't...
