ABS/Track control/ Brake light on after tire change
I redid the car in hp tuners to reflect the 295/50/15 rears 28" basically and have matching fronts.
I adjust in HP tuners for this and still getting these lights on the dash after driving some. Is there a spot I am missing? HP tuners has a tire change section and I used that.
Any assistance greatly appreciated.
Crap..... What are my options short of black electrical tape lol. I am assuming HP tuners just fixed the speedo then correct?
Its on 02 ws6 that had 275/40/17 and i went to 295/55/15 Front tires were changed out to similar diameter (very close)
Will changing this fix it? I read on HP tuners forum it may
I did the math on this, and that's not a huge change honestly. Your previous settings were about 2540/101605... ish. I suppose it's worth a try to reduce the ABS to the new values. Can't say I've done it though. I didn't have this issue going to the newer tires, and mine changed very similarly to yours. Maybe the sensor took a hit? Worth a look.
I will say, even with the PROPER math for everything, I still had to adjust and adjust using GPS to note the error at certain speeds. It's still off from displayed and what's in the scanner. I think this has something to do with the gear ratios, ISS and VSS error with the 4L80. I did the math on that too, and there is actually an explanation, but I just made real world corrections to the speedo cal using GPS. It's dead nuts on now, but the scanner is way off, maybe like 10% or so. I used to be able to explain why, but those penguins have since left the island.
Is a GM Tech II table able to adjust these levels? My tech friend tried and was not able to see where to even make any changes. I have tried modifying more and still randomly coming on.
Sensors in rear seem okay and are not overly dirty. These seem discontinued?
Front sensors/hubs are brand new with maybe 1000 miles on them. Had zero issues tel tire change
