Issue with not going into PE mode
It’s 2004 gto with ls1 with BTR stage 2 cam, ls6 intake/injectors, full bolt one. Previously had a LS3 in it that ran good. Put the original ls1 back in and am retuning (speed density). What’s odd is that commanded PE A/F is 13.0 in the tune, but from the screen shots I added of the log, the closed loop commanded A/F is constant, even when TPS jumps to 100%. This makes me think it’s a tune thing.
On a side note, I loaded the ls6 injector data, but my VE table is crazy high in order to get decent idle A/F. I will try and post up the tune.
The injectors are suspect... I bought them used from someone on hear overseas with an LS6 intake. Fuel pressure is mid 50’s based on the gauge mounted on the rail. I might slap the LS3 injectors back on and adjust the tune. Even at low rpm (from my experience) STFT drop to 0 and Commanded A/F changes to PE commanded when pedal is stabbed (pushed to 100%).
