LS376/525 Dies at hard accelerating/WOT
Hello, I hope somebody could help me.
I've the following engine https://es.chevrolet.com/performance...ines/ls376-525 with the GM performance management harness.
The engine works fine but it dies when I change gears (manual transmission TREMEC 6-Speed) and push the pedal fast to the ground. The issue doesn't appears if I push the pedal gradually.
I did the following tests:
- Change throttle body
- Change O2 sensor
- Change MAF
- Change air filter
- Check grounds
- Check fuel pressure (58 PSI constant).
Any idea?
Thanks a lot in advance.
- Change O2 sensor
- Change MAF
- Change air filter
- Check grounds
Any idea?
Hi, thanks for your help!
We installed the following Engine Controller Kit https://www.summitracing.com/int/parts/nal-19354332
I will try to get the tune file and datalog and upload this weekend.
Thanks again!
Thanks again!
Hi,
Attached is the tune file and the datalog that I did a coulpe of hours ago. The fault didn't appears. I did a coulpe of tests at different loads, but problem didn't appears. Despite of that I would really appreciate if you could take a look to the datalog and let me know if there is something appears to be wrong. I could't connect the O2 sensor to the MPVI Interface so you will not see AFR data in the datalog. The only thing that take my attention is the INTAKE AIR TEMPERATURE, the outside temperature was near 70 F and the IAT was allways over 100F.
Thanks again!
"The only thing that take my attention is the INTAKE AIR TEMPERATURE, the outside temperature was near 70 F and the IAT was allways over 100F.
With the air cleaner sitting in the radiator air stream, the IAT is going to be higher than ambient. A "cold air" box could help w/ the temp.
PD. Jajajaja .. me hiciste reir con el "boludooooo" ... y me alegró ver la respuesta en español. Tienes amigos argentinos por lo que veo ... jejeje
I double checked DTCs in HP TUNERS Scanner and appears DTC P0134. But the O2 sensors are brand new, its were one of the first things that I changed ... On the other hand, when the engine starts and during a couple of minute it didn't idle right ... then I push the pedal a couple of times and began to idle.
Excelente! Muchas gracias, voy a revisarlo un poco con la tool de comparación de HP TUNERS y probarlo. Dame unos días porque el auto está en un evento este fin de semana.
Www.hptuners.com loco baja el software donde dice downloads. Latest version. Si cuando lo instales toda tu info se pasa pala nueva version. Me actualisas aver como funciono ! Jaja si tengo varios amigos sudamericanos
Salu2
Salu2
Salu2
Salu2
1- Todas las modificaciones asociadas a parámetros de la transmisión (ej. ENGINE->SPARK->IDLE ADAPTATIVE SPARK CONTROL->OVERSPEED->P/N) tienen algún efecto en autos con transmisión manual?
2- En la tabla ENGINE->FUEL->POWER ENRICH->POWER ENRICHMENT->EQ Ratio (GAS), veo en general una reducción. Está ok? En teoría esto reduciría combustible
3- La tabla ENGINE->SPARK->IDLE SPARK ADVANCE->BASE siendo que aplica únicamente para IDLE que sentido tiene en los valores de RPM superiores?
Gracias por tu tiempo!
