CTS V1 Flex Fuel
Old Jun 13, 2019 | 11:07 PM
SE-R Spec's Avatar
Default CTS V1 Flex Fuel
I have been doing some research on installing a flex fuel sensor on my 05 V1 (P59 ECM with 12592618 OS) and tuning it.
What I have gathered so far from other threads is when people want to add a FF sensor to their Gen III ECM's, P01 equipped vehicles need an 02 FF Tahoe Operating System, or OS and from what I understand, the Tahoe OS has to match your stock OS or HP Tuners will freak out and say your OS and VIN don't match.
To avoid that, I've seen where people have upgraded to the P59 ECM's with factory FF. Some trucks have the same 12592618 OS as my V1 but as ShorTuning has stated in another thread, some parameters in the background of the truck OS, that we cannot alter in HPT, severely screw with the DBW aspect of the V1 and C5 Z06 due to I believe the readings from the TAC signal in the gas pedal.
Sorry for the long winded intro, but I thought it necessary as most of this info is from early 2018 and I know how quickly things change so I was wondering a few things. 1) Is it possible now with newer versions of HPT to segment swap only the FF spark blend and fuel tables from the truck 12592618 OS to work on the V1? 2) Is there any other solution to "unlock" the FF tables other than writing binary code like Shortuning has? 3) Could I swap to a FF truck P59 and then segment swap to the V1 engine parameters to keep the TAC happy and take advantage of FF?
Derek
Old Jun 14, 2019 | 09:12 AM
roughneck427's Avatar
Your factory calibration can be enabled. I use Tunercats and can enable FF on any P59 OS. What software are you using? I posted some xdf files in the FF thread for the guys using HPtuners for user defined parameters and I posted some cax files for the EFIlive users
Old Jun 14, 2019 | 03:29 PM
SE-R Spec's Avatar
I’m using HPT. I read where the V P59 has issues running FF, have you ran into this?
i will also look up the FF thread. Is it a problem if I’m not running 3 bar at the moment? I’m still N/A
EDIT: So the xdf files you posted up are for the 603 and 604 OS's, I have a 2618. I'm a little confused on how I can use those files. Would you mind explaining?
Old Jun 14, 2019 | 07:21 PM
No post your OS I can make the xdf file to enable the FF tables
Old Jun 14, 2019 | 07:47 PM
SE-R Spec's Avatar
Here is the latest tune I was working on today.
File Type: hpt
Old Jun 14, 2019 | 08:03 PM
ill make a xdf to enable the FF for OS 2618
Old Jun 14, 2019 | 08:11 PM
SE-R Spec's Avatar
I downloaded TunerPro and I think I get the just of it now but I cant download the OSID stuff from Tiny Tuner. Very interesting stuff and it sounds like you have mastered it.
Old Jun 14, 2019 | 08:42 PM
SE-R Spec's Avatar
That is awesome man, I really appreciate it
Old Jun 14, 2019 | 09:14 PM
Had issues uploading to the forum. PM you a drop box link with a stock 2005 L59 calibration and a picture of what values to put
Old Jun 14, 2019 | 09:32 PM
SE-R Spec's Avatar
Much appreciated!
