Injectors won't pulse
So, since the engine runs correctly under a prime condition doesn't that mean that the crank, and cam sensors are synced? I am under the thinking that it's an electrical gremlin. My harness is a CBM. I have been communicating with them for the last month. I think we are about one email away from me pulling the harness out of my car and sending it back to them for testing. I'm sure it's one simple thing, but what?
Yes thank you. I am aware of that, and have tested 8 leads at the ECM. Anything specific that would cause all the injectors not to fire? I have also done the noid light test, and it doesn’t light.
If vats are still active it will fire and shut off.
Cam sensor fires the injectors. Make sure its plugged in correctly.
And grounds.
Another thing is to make sure u have complete key ign hot to your pink wire with key turned to start/starter spinning. Usually easier to just jump this wire to straight battery to test a harness.
Which is why Gen III uses 2 "lobes" either on the cam or in front on the sprocket, and Gen IV uses 4 on the sprocket.
I've seen many instances here where if the cam sensor was DOA, it would start, but after a lot of cranking while the ECM "figures out" where in the cycle the engine is. The cam sensor mainly helps the ECM see where the engine is during the cycle.
Ive seen the same thing with a bad ground.
I agree the crank sensor is the main one for pretty much everything but the cam sensor does play a part as well.
thanks
