Determining an intake restriction on a boosted setup from logs
@turbolx @joecar @ChopperDoc @JoeNova @SLOW SEDAN
On an NA car it's very straightforward to tell from a log if you have an intake restriction. How do you do this on a boosted car, SPECIFICALLY when there is a boost curve and not a set boost pressure, but highly varies over the RPM range? Had a question from a member on another forum who said a shop told him he had an intake restriction on his boosted car from remotely looking at a log, curious how they were able to do this.
This is speculation on my part.
Pretty sure the shop is full of **** here. We might as well start analyzing random logs people post on here to see if they have air restrictions. Practically impossible if additional sensors are not used and logged. That and I'm pretty sure most shops just aren't going to take the time to crunch all the numbers and put that much time into a remote tune. And even if so, what numbers exactly could you use to tell if you are using stock parameters? There's just not enough information to come to a reliable conclusion.
