Cutout tune
i am about to order my exhaust. The turbos are 3” vbands so I am going to run full 3” exhaust and the cat back will be name brand so will have resonators and mufflers. I’m hoping car makes 7-800whp and was told at that level the catback will hurt me and to run cutouts.
That is fine with me, however, how do I manage the tune? Someone else will tune it, not me. Should I have the car tuned with cutouts open or closed? Will one tune be ok for both situations? Will it be safe if I tune for max performance with cutouts open and the close it and still beat on it once in awhile without cutouts?
I dont plan to always beat on it with cutouts closed but in the event I do, I don’t wanna blow it up either.
2) Tune it for worst case (Cutouts closed) so that you have the higher backpressure and residual heat in the cylinder for knock tolerance
3) Drive and enjoy.
3) Drive and enjoy.
Do you think ill be losing out on a lot of power? I’ve read a lot before posting and seems it could really run different when the cutout opens. Could boost higher too.
A MAF sensor just directly reads the airflow and lets the ECU adjust fuel/spark accordingly when flow changes. Since the GM ECU already has capacity for a great MAF measurement, I don't see why you'd want to throw that away in this case.
We have seen 100rwhp difference with cutouts open vs closed on boosted setups with full exhaust. In those situations all you can do is have 2 tunes and switch between them.
I would tune the VE table with the dumps open, but as it was mentioned before, tune the spark table and knock sensitivity with the dumps closed (as this is worst case for heat and back pressure)
If you find that you are able to add more spark with the dumps open then you could send a false frequency into the flex-fuel sensor pin to trick the vehicle into thinking it is running E85. Your flex fuel AFR table should be calibrated to 14.5 across the board, but this will allow you to use the flex-fuel spark adder table.
Essentially, when you open the dumps you can flip a switch that will tell the pcm to use the spark adder for flex fuel.
This is why I love this ****. So many possibilities.
It's almost like doing the 2 bar MAP sensor trick to an N/A nitrous car. It basically gives you 2 VE tables at the flip of a switch, by throwing an extra 5V at the MAP to give it 105-210 range instead of the normal range. Hell even that could work if this is a 2 bar, by throwing more voltage at it to make it think it's 3, and bam, you have an "extra" area of VE to play with.
More ideas... Not sure how well that would work, but if you want to be different, and run one tune, this is just another possibility.
Never thought of that use case, but I have tested it with a PCM and it works just fine. Just have to be careful how you wire the Arduino.
https://www.tinkercad.com/things/5Gu...nsor-simulator
i spoke finally with my tuner and he wants to use efi live anyways, he says he can tune a low boost setting with catback to its full potential and tune for high boost for its full potential on meth and cutouts open on the same map. He also tunes afew psi over the finished boost level as a safety restriction.
i guess efi live has no need for diff maps. Thought he was saying each psi he can use its own timing and fuel map. Could be wrong on that but it’s the way it seemed. Either way, works for me.
