New engine starts and dies
Old Oct 24, 2019 | 02:23 PM
robert19890412's Avatar
Default New engine starts and dies
Got my new ls2 402 stroker installed and started. Wont run for more than a few seconds does it need a tune to run? Also car is a 98 corvette.
it has cam that is .612/638 at 112
ls3 heads and intake manifold
ls2 throttle body
42lb injectors
ls2 map sensor and cam sensor
Old Oct 24, 2019 | 02:42 PM
You gave the lift but not the duration, which is actually more important.
Old Oct 24, 2019 | 02:53 PM
Oh read that wrong
274/286 612/638 @112
Old Oct 24, 2019 | 02:58 PM
Originally Posted by robert19890412
which means what exactly? The engine will not run?
Hey YOU mentioned the cam. Lift and LSA don't affect how an engine runs NEAR as much as duration.
But as far as starting and dying, it might be VATS staring you in the face. Why, I don't know, but it happens.
Old Oct 24, 2019 | 03:00 PM
Oh read that wrong
That's advertised. Do you know the .050 spec? That's more commonly used nowadays.
Old Oct 24, 2019 | 03:22 PM
Old Oct 24, 2019 | 03:27 PM
224/234. Thank you. Nice lumpy cam!
Old Oct 24, 2019 | 06:04 PM
Is this why it isn't idling?
Old Oct 24, 2019 | 06:52 PM
How low are you setting the idle? It should idle around 800RPM
Old Oct 24, 2019 | 08:57 PM
It idles for maybe 10 seconds throws a p0101 code and stalls. will only restart if i clear the codes.
Old Oct 24, 2019 | 09:29 PM
No, I asked for the idle speed setting.
Old Oct 24, 2019 | 09:45 PM
stock, it hasn't been tuned.
Old Oct 24, 2019 | 11:25 PM
Stock idle is around 500 RPM. That cam won't idle at that speed. You need to tune that engine.
Old Oct 25, 2019 | 02:05 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Stock, with no tune, the change in displacement, the bigger injectors, or the cam would each by themselves keep it from running. Even just the heads, intake, and TB change would make it idle poorly if you had put in on the stock motor. With everything together, I am surprised it even tries to start.
Old Oct 26, 2019 | 07:37 AM
Darth_V8r's Avatar
Moderator
Short answer to your original question, yes you need a tune.
Set displacement correctly
Dial in VE tables
Dial in maf
Dial in timing
Raise idle speed
Program all your idle controls
Set correct fuel injector data
That's the short list.
