LQ9 into 02 z28 computer/ harness question
I am planning on swapping an LQ9 into my 2002 z28 6 speed. Was wondering what year LQ9s I should look for because I would like to use the harness and computer from the camaro. I’m not sure if everything will cross over and I have searched a bit on this but didn’t find much. Thanks
I got an LQ9 370 long block from TSP about a year ago. Installed it in my 98 Z28. I don't recall we changed anything except for a couple of things that won't apply if its takeout from another vehicle.
The new blocks are a little different from the original block - all long head bolts for example. GM doesn't mfg the original block anymore according to TSP. I recall we did have to tap a hole for the alternator bracket.
One thing I recall when I was searching for info same as you. Don't recall exactly, but it had something to do with the crank on the backend- longer as I recall maybe. Jason or tech at TSP is your best source for answers. Do a search on this forum too.
In my case I had no issues.
The following users liked this post:
G Atsma (12-23-2019)
