99 t56 Fbody to 4L80e swap, want to keep dash working, what pcm to use?
Hi Gurus, I've just banshifted and sent into space a piston and now I'm going 4L80e
The question, what computer and harness would you use, the 99 computer and somehow control the 4l80e. Or put the 2002 LQ4 computer and somehow make the BCM/dash work. And based on your decision, what would it take?
BTW Using HPTuners
The car
Option 1:
Thanks!
BTW Using HPTuners
The car
- Camaro z28 1999 3bar SD T56 manual
- OS 9373372 converted to 1263008 P01
- working dash, speedo, fuel level
- Silverado 2001-02 LQ4 DBC
- complete harness with PCM (last digits stamped 0411), I guess the hardware is a P01
- 4l80e
Option 1:
- keep my 99 pcm and 99 harness
- write complete a 2002 camaro 4l60e (extra credits?)
- segment swap a 4L80e from truck
- just pin the extra transmission cable and vss
- cross fingers
- write complete a truck 6.0 stock file (extra credits?)
- cross fingers (do I have to re pin something else?)
- put the harness of the 01-02 silverado and PCM into my camaro
- how to connect that into my dash,bcm, etc... ?
- put the PCM of the 01-02 silverado directy on my 99 camaro harness
- add extra transmission connector and vss into the 99 harness
- Do I have to repin something else???
Thanks!
Hey there,
I'm still slowly getting into OEM tuning so you might want to take what I say with a grain of salt.
Firstly, since both PCMS are P01s it's a bit simpler, the biggest variances from what I've gathered is how the O2s are pinned. I personally think that using 01-02 PCM would be the easiest option, the BCM and PCM communicate using the serial protocol and the only signal that the PCM sends to the dash is the tachometer and the rest are from the senders(grain of salt here). I think that as long as you change the VIN on the new PCM to match the VIN on the BCM its plug and play. I could be completely wrong but that's what I've gathered over the last couple of months.
Use your pcm and segment swap the trans to an 80e. Plenty of segment swap info around. Make sure to do a write entire after the segment swap. You’ll need to either buy a harness for the trans or make one, its only a handful of wires. https://www.speartech.com/product_p/4l80eaddon.htm
Somehow found in here a 99 4l80e truck with that specific OS https://forum.hptuners.com/showthrea...80-O-S-9373372 , did just the segment swap with my original 1st read . Did a write entire and then bricked like at 80% write (with a trusted bench harness).
Now here is the question:
- are those 99 4l80e stock files trusted?
- if going with my spare pcm (the same 99 OS 9373372 converted to 1263008) from 99 to 2002 SO, segment swapping 4L80e and then doing a 3 bar custom OS, shall I write entire for each step? or shall I use the new segment swap file, apply 3 bar to the segment swap file and with the newly saved file shall I just perform 1 write entire?
Thanks
Thanks
Ok here are the results, it might help someone
Fried 1 pcm, I don't know why, that was before the post.
Now the successful steps, using a fully charged battery (no more ac adaptors) and bench harness and laptop just on battery:
- write entire original read (from 3 bar to stock)
- with that original read entire, applied a 99 4L80e segment
- saved the new file
- write entire the new file
- cycled 2 times the pcm
- with the segment swap file, I applied 3 bar OS, putten the correct 4.8 engine size, other ton of stuff and then saved it in another file
- made changes to flattened tables, put in my injector data and other ton of stuff
- saved it as a new file
- write calibration
I haven't tried the pcm, but at least I know it is responding and definitely it will start the car. No bricked PCM
And for what I see, the 99 file of the this post named 1999 sierra is working for segment swaps https://forum.hptuners.com/showthrea...80-O-S-9373372 with a 9373372 OS. I remember when all over the interenet there were no 9373372 4L80e files.
- write calibration
The following users liked this post:
G Atsma (01-22-2020)
