Speedometer adjustment, HP Tuners.
I'm guessing it has to be in the Tran/Rev per mile adjustment. But I'm not sure what exactly I need to do to get it where it needs to be. I followed this guy in the videos instructions to a t. I've got the speedometer working perfectly its just the trans isn't shifting right. Any advice is more than welcome. I'm using HP Tuners.
I don't believe I've ever went to the speedo tab to change something afterwards. That's the whole point of the gear wizard, it does everything for you. At least in my experience.
I have seen if its hitting the limiter and not shifting, you need to lower your RPM and or MPH. I can't remember if the PCM needs to see RPM or MPH first to actually command the shift.
