Odd idle after WOT
Any tips on what this might be?
https://forums.holley.com/showthread...neral-IAC-Info
I made one modification to my tune recently. I made the the IAC Effective Area no lower than 35 steps. So when the ECU requested lower airflow, there was no way to go below 35 IAC steps. This "worked" and the car didn't die but the car just behaves so odd after getting on it. Idle is way too high when going down the road and when coming to a stop the Idle Desired will sit there and fall and fall until the ECU is requesting 0!!
I'm so frustrated. Even more info, I found a data log where I went WOT and the car did not have the issue and one where it did. The worst part was I made no mods between the two logs. I'm 100% sure of this, there are only 4 days between the logs.
My next test is to see if it's load based or RPM based. Just going to manually downshift the car so it hangs out at a high RPM for a sec. At this point, the only sensors that are the factory 30k mile sensors are the cam position, knock, ECT, CPS, and IAT.
I have a legit, no-BS $50 beer bounty for whoever has the winning answer. Venmo, Paypal, hand delivery, your call.
As a reminder, I flashed my tune on a known good 0411 ECU and the issue was still there. As a last ditch before replacing the harness, I got yet another ECU and rebuilt the tune on a newer 12212156 OS and the issue vanished. Overall idle quality is way better too. I wish I could say I knew why the car ran great and then suddenly had the issue with no changes, as verified by logs I was taking, but I have no idea. Car runs great, super stoked with it. Highly recommend 12212156 to anyone for the better idle alone.
