Why do I go lean after a cold start for a few seconds?
Old Aug 8, 2020 | 06:56 PM
echo412's Avatar
Default Why do I go lean after a cold start for a few seconds?
Hi guys, would love to hear your opinions on these questions:
1. Why do I go lean for a few seconds after start up. It does it every single time right after a cold start.
2. Based on the quick pull (15:53 minutes into the log), do I have a too big of rear gear?
Some additional info:
-Car is 85 RX7 FB GS and probably with me in it weights ~2700lbs
-LS1 5.7, LS6 cam/intake, 317 heads, 60 lb injectors, T56 m6, meth comes on at 5lbs and runs on 93, OLSD
-I asked for 3.55 rear when I got my 8.8, but I now doubt it and feels more like a 4.10.
-I am a novice tuner and never tuned a car before this car, so any other "constructive" feedback is appreciated
Thanks
File Type: hpl
Old Aug 9, 2020 | 10:38 AM
echo412's Avatar
Any ideas why I get that lean spot every time?
Old Aug 9, 2020 | 12:39 PM
My guess is that when cold, gas does not vaporize as well, nor burn as completely, leaving more unused oxygen in the exhaust, which would then show as a lean condition. And the fact that it's only immediately upon a cold start, and only for a few seconds, means it's all normal.
Old Aug 9, 2020 | 03:10 PM
echo412's Avatar
That’s an interesting thought. Anyway I can improve that situation?
Old Aug 9, 2020 | 03:14 PM
Since it's for just a few seconds on cold start, is it really a problem? Let it warm up a bit until it is running well, by which time the A/F ratio is better.
Old Aug 10, 2020 | 09:00 AM
echo412's Avatar
Any others?
Old Aug 10, 2020 | 09:08 AM
Kfxguy's Avatar
your idle fueling is too lean so right at first its not using the fuel trims. Fuel trims kick in, it goes to normal. Add a touch of fuel to the 400rpm and 800rpm range. Maybe Just one or two numbers.
Old Aug 10, 2020 | 10:50 AM
echo412's Avatar
Great, I'll try that, but I have a novice question. I am in open loop, would trims kick in and correct in OL?
