OBD2, oil level?
Old Dec 17, 2020 | 11:38 PM
general23cmp's Avatar
Default OBD2, oil level?
I have a 2002 engine, red-blue PCM. I know the computer originally sent my oil level warning through the BCM serial to the dash. Does anyone know if this is also in the OBD2 data? I’m doing a dash conversion that uses OBD2 data and I’m wondering if that sensor might be able to be seen by it.
Does anyone have a list of the available parameters in our OBD2 stream (rpm, coolant temp, etc.)?
Old Dec 18, 2020 | 08:39 AM
minytrker's Avatar
You will not be able to see oil level through ODB2 with that pcm.
Old Dec 18, 2020 | 10:19 AM
Thank you, and just to be clear, I’m talking about oil level in the pan, not oil pressure. I think I get oil pressure through OBD2 (depends on vehicle/engine).
Old Dec 18, 2020 | 12:12 PM
minytrker's Avatar
Yes oil level will NOT work. Oil psi will not work either through odb2 if your using a 2002 OS and a single wire oil psi sending unit
Old Dec 25, 2020 | 06:36 PM
Pacer Racer's Avatar
it isn't a true level sensor, in the oil pan, it is low level switch. It turns on when the level is too low
Old Dec 25, 2020 | 06:43 PM
Yeah I know. Thanks.
Old Dec 25, 2020 | 08:30 PM
2knight's Avatar
I hooked mine up to a light on dash but it comes on every time i corner, accelerate, or brake hard. On stock vehicles it never comes on unless about 2 qts. low. So how does it get wired on a stock car or truck to keep it from giving false alarms? Does it route through a computer that only turns low oil light on when there is a constant signal from low oil sensor for a predetermined amount of time to prevent false alarms?
Old Dec 26, 2020 | 11:34 PM
That’s good info. I figured out an easy circuit to reverse the signal from a ground break (I think that’s how it originally worked) to a ground applied trigger, so my light would come on when grounded.....but like you said, there is no delay or persistence built into it. I might be worrying about something that simply isn’t going to smoothly work the way I want it. I need to think about my circuit now to see if there is an easy way to require it to be grounded for X amount of time.
Old Dec 28, 2020 | 06:02 PM
2knight's Avatar
Yes thanks for reminding me I had to wire it to a relay with ignition power to reverse the contacts or the light will stay on all the time and go off when oil level low, I ended up disconnecting the light all together because it was constantly flickering on when cornering and driving around. I did install a new sensor thinking the used one was possibly bad but same issue. It would probably work if you had a timed delay of a minute or so to eliminate false alarms, I figured for the extra trouble I can check the dipstick every so often, just would be nice to have it functional. The factory must have it on a timed delay through a computer possibly the bcm? to figure out when its actually low and not just sloshing around.
