Trans Tune Issues w 4L80e?
Old Aug 26, 2021 | 04:50 PM
korndawg's Avatar
Originally Posted by minytrker
Yes that will turn off misfire, you can also raise the rpm test.
Thanks. I will give that a shot next!
Old Aug 27, 2021 | 11:22 AM
Kawabuggy's Avatar
Drilling down on it I see... We are all rooting for you!
Old Aug 29, 2021 | 11:05 AM
korndawg's Avatar
Woohoo! The new tune and getting rid of the misfires codes finally made it lock up! Shift firmness is soft so I'll work on that. Also, the trans still heats up way too fast (guess due to the radiator heating it up) So i'll be installing at B&M 70266 this week. Hoping thats enuff to cool it down. I could have fit the larger 70274 but I still wanted plenty of airflow going into my HX. Will see if this all works. I'll post my logfile. Thx for everyones help!
File Type: hpl
Old Sep 1, 2021 | 02:24 PM
rpturbo's Avatar
So just a fyi, I have a second gen S10. I had my cooler going through the stock radiator, and then out to a stock 00+ Silverado transmission cooler and back to the trans, and it stayed under 200*. That little stock after cooler knocked about 20* or so out consistently. If you get a nice aftermarket cooler in front of your radiator, you should be under 200* no problem.
