Trans Tune Issues w 4L80e?
Is your trans cooler a stand alone unit? Or part of the radiator?
I noticed in your log that the converter never locks. You should log mph, and then compare to your lockup tables.
Also add Trans Current Gear.
This should be locking in 3rd above 35mph.
190 isn't too hot, and if your cooler is in the radiator, the trans will run near engine coolant temp. It doesn't have a choice.
Myself, I prefer just a stand alone cooler.
250 is too hot, so don't let it get there.
Ron
Ron
go ahead and add this pids to hptuners and repost results tonite. I too noticed that I never seen the converter lock up.
Will be much cooler with a separate cooler not plumbed inline with the radiator.
Same issue with my turbo car. So I mounted the cooler under the car. Have to admit I don’t have a temp gauge on that car. It’s a TH400.
4L60 in my vette never gets past 175 with the separate cooler up front.
Your tune indicates 26” tires and a 3.70 rear end ratio. Is that correct?
I'll do some research on an inline cooler. Just need to make sure I can get airflow to it!
Your 1972 Chevelle is NOT WIRED correctly from the factory to pair the brake pedal switch with the TCC lock up function with the PCM. Check your BLUE connector, Pin 33... When the key is in the "RUN" position.. you MUST HAVE 12+ at that wire.. If there is not 12V+ on that wire when the key is in the run position, you will NOT have TCC lock up.... If you find you have no wire there... Just add a wire to that cavity and give it 12 volts + (positive) when the key is ON/RUN.
Also... you did not mention what year 4L80E trans you are using.. If you are using a 97 or later, that has the cooler lines spread apart... You must be very careful that the REAR cooler line fitting has the 1.5" long nipple on it... I've seen it happen often that guys will go over to braided stainless line and put a cooler line fitting in the rear position that does not have that nipple on it.. no nipple will show up early as a trans that gets hot quickly.. But shortly you will DESTROY the entire gear train assembly inside requiring a full rebuild, and starting with another core as so much stuff will be completely destroyed requiring another complete trans. I try and steer customers away from braided stainless.. The factory steel lines actually act as heat exchangers for their entire length.. Braided stainless lines actually INSULATE the heat, holding it, inside the lines putting more work on the trans cooler(s).. I get that steel lines don't look "racy" but they darn sure help in cooling the trans fluid down. Regardless, check the rear most cooler line fitting before you do anything else.. look at this;
https://www.ebay.co.uk/itm/282758081...kaAjTnEALw_wcB
you gotta figure out the no lockup situation tho. can you command it to lock with the scanner?
Ron and i just wen thru this in his buddies rig. Had 3 grown men scratchin their heads for a couple weeks and it turned out to be a bad converter.
I'm not sure if it did attach properly or not but my HPT log file and scans are posted in my original post? The trans I am using is a 1993 core so both of my coolant lines are up front. I'll check w/ my tuner to make sure he has the misfires set to ignore. or at high enough levels to not read. I haven't seen any lately show up on my scans however yes, its a good idea to double check. I am confused on the factory wiring to the PCM you stated. That is def something I'll need to check! I purchased a complete LSA4l80e hardness from BP Automotive so I can't way one way or another right now if its in there. \
I am using braided steel lines with reflectve heat sheilds going around it but it makes sense what you're saying w steel lines. Something else i'll check.
One thing I am 100% doing because I overlooked and took it for granted. SInce my cooler is only on the radiator, it makes sense why it heats up fast and at the same temp as my water temp. I'm gonna go with a B&M and find a spot to mount it up front. I already have the Condenser/HX/Radiator in that stack, but I can prolly fit a B&M 70264/70263 or 70266 up front. I'd like to get the smaller of the 2 to help increase airflow through it all. Do you think the 7064 would suffice? Thanks for the response!
Weather looks good for tonite, so I can go out and try the tune changes and see the differences.
The tune I'm 100% the is correct so issue lies else where. I'll check that wiring you told me about and go from there. After that, I'm fresh out of ideas. Do I want to max out all of those to 32767? I do have the code disabled in DCT.
