Car revving super high on cold start
Car was tunned with vacuum leak was told by tunner really wanted to fix it then have it tuned but he went ahead and tuned it anyways car was fine just idled a little high… had vacuum leak fixed then car was out of whack, super high idle so i decided to chance IAC to see if it was the issue but it wasnt no clue what else to look for dont want to damage engine. Car is a heads/cam auto.
car was tunned with vacuum leak was told by tunner really wanted to fix it then have it tuned but he went ahead and tuned it anyways car was fine just idled a little high… had vacuum leak fixed then car was out of whack, super high idle so i decided to chance iac to see if it was the issue but it wasnt no clue what else to look for dont want to damage engine. Car is a heads/cam auto.
Cant understand why they would tune it with a vacuum leak. Sounds like trouble ..
I would not be surprised if all your bottom end fuel and spark tuning is out of spec..
Basically I'd assume if it was tuned with a vacuum leak ,, all that work went for nothing and it needs re-tuned.
If it had that big of vacuum leak when tuned and now its fixed it should not want to idle. The leak would have been adding additional air so they would not have had the correct idle air in the tune with the leak, without the leak it should need more idle air to idle. Its possible more than just the idle air is off.
The following users liked this post:
G Atsma (12-04-2021)
