LSA E85 Remote Tune Possible?
Seeking local or remote “tuner” recommendations for my E85 LSA build. Engine will have 224/232 cam, 10.5-11:1 compression, 1300cc injectors, and 28% increased blower drive. Engine is standalone and will be going into a boat. I do have HP Tuners, dual wideband sensors, run stand, and shorty headers to test fire and run, but no dyno to load until it is in the boat. I do have the stock E67 with original LSA cal in it as a starting point.
Would this be able to be done remote? Get a base established on the run stand for start and idle, then send logs once running under load in the boat?
Thanks for the advice and guidance.
I would go for the engine dyno.. A super flow with a wet load cell would probably be optimum.
Super flow at one time had a Marine setup on some versions that models the power load like a prop.
Once tuned on the dyno, the fine tune on the water should be minor especially if you can find a boat tuner,,
check in to sprint boats the run some wild stuff and would know a guy.. I don't believe any car tuner is going
to nail it unless they already do boats. Its such a different load profile.
I'd probably just install a Stack or a waterproof laptop in the boat. You also should invest in a alcohol test kit.. (See dirt track or aircraft suppliers, or chemical suppliers)
E85 is very erratic at alcohol levels in the general distribution chain.
Find a local chemical supplier and buy a drum of pure ethanol or a Drum of E100 from a fuel distributor to adjust the pump fuel with.
OR
Long shot don't know if they still play in the game or not,, Family that owned Milton Freewater Chevrolet in Oregon was a key developer for the 502 chevy's with GM..
They had a cigarette race boat program and likely know how to tune the engine for a prop application, as well as properly prop the boat for your performance desires..
edit-- No matter if the tuner knows boats or not if they are doing it in person. You tune FI off sensor readings, engine noises, plugs, etc. Does not matter road or water.
Boats commonly hit places and live in parts of the VE that cars don't.
Boats run at WOT for extended period of times compared to cars WOT blast. i.e., timing, cylinder temp, Lambda
@FormulaBoat if local is the Chicagoland area I think I know of someone who has LS1 and marine tuning experience.
Ears still on for any additional input.
