What ECU for a boat?
Once you get used to adding special inputs and outputs to the Dominator, it is hard to go back to a non-expandable factory ECU.
Your boat, your life so do whatever works for you.
My 98 Wrangler with a LS6/4L60E combo has the ECM mounted under the brake booster. No salt air around here but many days of snow dust in the winter. Rain in the summer. Engine heat. Never an issue in the 15 years since I did the swap.
You probably don't know or didn't realize that every watercraft with a deck has a bilge, the area between the deck and the hull. Every bilge has the potential to fill with gas fumes because thats where the gas tank(s) are mounted. Which is why they are fan vented, also specifically designed as shockproof. EVERY piece of electronic equipment mounted in a boat from the radio to the horn to the ECU/ECM MUST BE Coast Guard approved as shock proof or it is non compliant equipment and extremely dangerous for a marine environment.
https://webstore.ansi.org/standards/...e11712011j1171
No idea if that is enough to pass a Coast Guard examination, but just for what is might be worth.
some of the jankyest wiring ive seen is on boats.
Now are you talking about lake boats or offshore runners? While your lake boat can be an electrical nightmare with wire nuts and lamp cord because you see land in any direction you look, not to mention being on fresh water an offshore boat is a very different animal. Living on an island in the North Atlantic made me take safety more seriously than the guy dropping his 9hp johnboat in the lake for some bass fishing. Safety and compliance with regulations was drilled into me by my WWII Navy father and thats how I approached boating especially since my kids lives were involved. The ocean doesn't forgive mistakes or give 2nd chances and it loves to kill off the stupid who venture out unsafely. Come the summer season there are several small craft that disappear offshore mostly because to them "its just like driving a car". Sometimes weeks later they float back in, most times they don't.
