Replacing PCM need to know what computer I have
Old Jul 16, 2023 | 05:47 PM
weinerschizel's Avatar
Default Replacing PCM need to know what computer I have
I have spent a couple years trying to sort out what happened to my Speedometer. In process I discovered corrosion all over my PCM & terminals. I cleaned all that up, which resolved some issues. However, speedometer never came back. I tore apart the harness, cluster, and pulled the PCM. First bench test of PCM passed. I put it back in car, started it up and the speedometer moved but then stopped responding after about 10 seconds of driving. I pulled PCM again, only to find out it wouldn't pass my VSS bench test again.
Long story short, I'm going to get a second PCM and try it. I'm not 100% sure what I have currently nor how to burn the VIN number into the new one.
Vehicle is a 1999 C5 Corvette. Throttle by wire setup. It's custom tuned, and I've downloaded my tune using HP Tuners.
Old Jul 16, 2023 | 07:16 PM
RonSSNova's Avatar
Find a 4896 or 0411 pcm.
you will need to license it, then do a “write entire” with the tune you read from the car.
Old Jul 16, 2023 | 07:45 PM
Assuming those are the last four digits of the SERV.NO. ?
Thanks for pointing that out. I'm looking and the 0411 PCM is slightly faster / newer. I assume will work as a direct swap once programmed correctly?
Old Jul 16, 2023 | 08:29 PM
RonSSNova's Avatar
The two function identically.
I don’t believe the 0411 is better. Just later.
Old Jul 16, 2023 | 11:03 PM
Anybody played with this? LS Droid...
https://play.google.com/store/apps/d....lsdroid&pli=1
It's possible I could flash the new config for free... I saw it years ago but didn't have a use for it then. It just came to mind talking with a mechanic friend of mine about this little project.
Old Jul 28, 2023 | 07:02 PM
Ah H.E. double hockey stick!
I ordered a PCM off eBay. Photos showed a SERV.NO. 09354896 which is what I have. They sent out a SERV.NO. 12583827 instead.
I don't know anything about this one... Would it fit? It says Blue on one connector and clear for the other...
Old Jul 28, 2023 | 09:53 PM
Pulse_GTO's Avatar
You need one that says blue and red.
Old Aug 11, 2023 | 08:26 PM
Got new PCM seems wasn't my issue afterall. My speedometer still doesn't work. ug.
