LSA Swap - No Crank Issues
Completed an LSA swap back in 2020 and it's been running like a champ for two years without any major issues. Went to a car show in 100 degree weather and had some cooling issues. Went to add an oil cooler and beef up the trans cooler as well. Didn't touch any of the wiring whatsoever and now the LSA won't crank at all. When I turn the key to crank, I'm no longer receiving a 12V signal to the to the starter. Did bridge from the positive terminal to the solenoid and the starter immediately turned over - so no issue there. I plugged in my HP Tuner to check the DTC's and the following came up. Note: LSA Coolant pump is running fine, fuel pumps engaged/ON, and everything seems to be fine. I'm just stuck and self admittedly I just don't have the knowledge to troubleshoot further. Is it something to do with my O2 sensors? I recall I had an issue with the intercooler coolant pump output from the PCM detecting the pump was running and the same issue occrred where it would not send signal to starter. Car was running fine and now it's not. And to throw it wrench in it - trying to take this car to Hot August Nights in Reno next week and then this happens after 2+ years of running great. Any help is appreciated and thank you in advance to the community.
I don't know what vehicle you have, but doubt it's anything related to O2 or anything like that. But the wiring diagram may reveal anything else on that circuit.
The car is a 66 Impala with a OEM wiring harness. The LSA wiring harness is from PSI and those guys were great to work with. The wiring diagram is exactly as noted from PSI - been working and running great for almost 3 years. I double-checked all of the fuses and verified voltage output from the relays (12.7V's). This really has me stumped and I'm wondering if there is anything I can look in the PCM to (HP Tuners - Scanner) that could lead me to a fault of some sort? As you can see in the pic from above, could I be having an issue with an O2 sensor? Does the PCM do some sort of validation and if an O2 is bad, doesn't allow the car to start? I guess I can go down the process of elimination and replace the O2's.
Either way fellas - really appreciate the replies and guidance.
FIXED! Ended up being a burnt up ground in the harness from the header heat. I wrapped the headers with the DEI titanium product, but my under the hood temps are getting really hot. I had no idea the supercharger would add this much heat. I was also told that my tune may be the issue for the heat - adding too much fuel. I had the car tuned by supposedly the "best" in the bay area, but not 100% I agree with that statement.
Thank you all for leading me down the path of checking all of the wiring - you were 100% correct in your assessment and I can't thank you guys enough. Very much appreciated and now this old guy gets to go to Hot August Nights!
