Help me find this knock please
Old Jul 27, 2023 | 08:24 PM
Tramminc's Avatar
Default Help me find this knock please
LS motor knocking - YouTube
Sounds mechanical, or can it be tuned out.
C5R motor, LS7
Old Jul 28, 2023 | 08:13 AM
01CamaroSSTx's Avatar
What was the oil pressure like when doing this? Although it does sound valve train related I'd try to pinpoint just exactly where the sound is coming from. Also I'd inspect the engine oil and cut open the filter and examine the filter element looking for any signs of bearing material. You could also get an oil analysis and that will tell you if it's bearings or not. Anyway that's where I would start.
Old Jul 28, 2023 | 08:22 AM
Tramminc's Avatar
no broken valve springs. I thought it was bad lifters, installed new ones, oil pressure is 30 at idle raises while revving.
Old Jul 28, 2023 | 10:38 PM
slothman's Avatar
oof. sounds like rod knock to me. I would do a compression test. and look at the oil for metal.
Old Aug 1, 2023 | 05:52 PM
Tramminc's Avatar
Looks like copper pieces and others in bottom of oil pan.
Old Aug 1, 2023 | 05:53 PM
Tramminc's Avatar
Will be sending the bottom block out to be rebuilt
Old Aug 1, 2023 | 07:48 PM
slothman's Avatar
sorry to hear that man. go with some nice forged parts on the rebuild ! may low compression for boost !
Old Aug 20, 2023 | 08:30 PM
Tramminc's Avatar
cylinder #1
builder found the knock, I told him to check everything
Old Aug 21, 2023 | 12:02 PM
Tramminc's Avatar
All the bearing need replaced. So much for not driving it in 14 years, only starting it every month or two.
Old Aug 21, 2023 | 07:22 PM
If your REMOTELY interested in selling that block, send me a PM.
