cooling fans amp draw
Do the engine RPM's drop when the fans come on?
If so, you might have to add some airflow in the tune for when the fans kick on to keep the RPM's up so the alt is spinning fast enough to charge.
What crank/alt pulleys are you using?
My mechanic and I are in agreement we are on the border line on if we are discharging or not with everything turned on. If I am idling with nothing on I am at 13,8 when I hit the lights it will drop on the gauge but then go back up some as it looks like the pcm is allowing the alt to make more volts, Then when I turn on the fans its drops again but will recover some. If I revere it up it will go up some. I think the alt is doing everything suppose i just not sure if it is enough. I am running some type headlights that i know pull my juice then factory.
How big is the wire coming off the alternator? Does it run directly to the battery to a BJB?
Many sets either use 2 fans (at 15-20 Amps each) or a 2-speed fan. Most ECU's can run a dual/2-speed setup, starting one fan at e.g. 190F and the 2nd at 200F. Perhaps your fan are full blast at the lower temperature. Of course max fans are needed when the car sits in traffic idling on a hot day.
Rick
