Diagnosing Idle Issues
Old Oct 22, 2023 | 05:04 PM
trever20's Avatar
Default Diagnosing Idle Issues
Finally got my LS swap running again after about a year. Last year, I had all the machine work done and completely rebuilt it and had it running on a stand. Over the last year, I have put the motor in the swap vehicle, completely reworked the harness, swapped out the factory intake for a TBSS, upgraded to 50 lb nnbs injectors, and reused the old 78 mm nbs throttle body via an adapter plate.
Couple questions - first, I cannot get it to idle on its own without around 10% throttle input (read through a scan tool). Once you give it some throttle, it runs decently but seems to run pretty rich. The only tuning that has been done was VATS removal from Brendan at LT1 swap, just so I could get it to run on the stand last year. This was before I changed out the manifold and injectors. Additionally, today I noticed the TB adapter plate I had did not have the relief cut in it for the IAC. I plan on ordering the correct one, but in the meantime, I cut a relief in my current one and it did not seem to really do much. I confirmed my IAC is working properly.
So, how can I get this thing to idle? I know the tune way out of whack now for the current manifold/injectors, but I figured it should at least idle or run somewhat? Should I send the computer out to get tuned for the current manifold/injectors, then reassess the issue?
Also, I am currently running no O2 or MAF, because I was just wanting to do a test start on it. Hoping you guys can point me in the right direction.
Thanks
Old Oct 22, 2023 | 05:59 PM
Kawabuggy's Avatar
Do you have hp tuners? Can you post a copy of your tune?
Old Oct 22, 2023 | 06:07 PM
Redlined2000SSLS1's Avatar
I’m going off the statement that VATS is the only tuning, and assuming you don’t have HP Tuners. You need to get it tuned before starting it again, larger injectors without tuning can wash down the cylinders. I would guess you don’t know if the PCM was tuned for the throttle body your running as well. Fuel and air have to be close for it to idle without intervention.
Old Oct 22, 2023 | 06:28 PM
trever20's Avatar
Correct, no tuning other than VATS (and whatever else Brenden did to allow me to run it on a stand). I do not have access to HP tuners. So, would the next logical step be to send the computer off to Brenden again and give him the specs on the new injectors, manifold, and TB? Or am I better off finding someone with hp tuners?
I live in California so there’s not a whole lot of options in my area as far as tuning goes.
Old Oct 22, 2023 | 07:35 PM
I feel you on the tuner situation. I’m in MS, three hours plus from the nearest tuner worth a darn. I did have mine Dyno tuned. WOT was good, but driveability was bad. I ended up buying HP tuners. No one will spend more time getting it right than you will. Remote tune is ok to get it running, but to get decent manners on the street and performance at WOT, it will need a full tune by you or someone you hire. If you decide to dive into the tuning world, there are a ton of resources available on here and hptuners forum.
Old Oct 22, 2023 | 09:15 PM
trever20's Avatar
I do plan on finding someone to dyno tune it when it is road worthy, but I’m thinking for now it would be worth while to do at least do another mail order tune just so I can start it and idle it.
does anyone have any tuner recs? I know many have used brenden from LT1 swap but I’m open to any recommendations. Also, does anyone know of any good tuners in California? I’m located in the Bay Area.
tia
Old Oct 22, 2023 | 10:52 PM
NSFW's Avatar
It's running rich because the new injectors flow a lot more fuel than the stock ones. That probably also explains the need for extra throttle to keep it idling.
If your PCM is a P01 or P59 you can fix that yourself with PCM Hammer - http://pcmhammer.org/
Setting up new injectors is not a bad way to get started with tuning. Just getting the flow rate right will improve things a lot, and you can fine-tune the rest little by little if you need to.
Old Oct 23, 2023 | 10:26 AM
trever20's Avatar
Thanks, I'll look into that. Is it a fairly simple tuning software, or would it require some knowledge to use it? I have never even attempted anything like that, so I'm thinking I might be better off with a mail order tune or finding someone local. I've heard of LS Droid as well but from what I've read, it can be a little complex.
It looks like LT1 swap only does VATS delete tunes. Does anyone know of any vendors on the forum or elsewhere where I could mail a PCM for a tune to get me up and running? Changes to the motor include cam, milled heads, intake, injectors, etc... nothing too crazy.
Old Oct 23, 2023 | 05:43 PM
trever20's Avatar
Another question for you experts - how much damage could I have caused trying to run the engine on 50lb injectors/stock tune? I was working on it most of the day, but total run time had to be well under 5 minutes, probably less. Should I change the oil, get a proper baseline tune, and not look back?
Old Oct 23, 2023 | 10:06 PM
See this thread. Some of the real experts commented on this one. Same case, heed their advice.
https://ls1tech.com/forums/generatio...built-lq9.html
Old Oct 24, 2023 | 12:38 PM
trever20's Avatar
Thanks, will do. Can anyone else give me some reassurance? I'm guessing I really did not run it long enough to have any affect but I want to make sure I do whatever I can to prevent further damage. I plan on changing the oil with fresh break-in oil (again), new filter, and get a mail order tune asap. I did pull the plugs and they were fouled but not terrible - cleaned them up and threw them back in. Anything else I can do?
Thinking I will go with LSX power tuning for a mail order tune. Anyone have any experience they can share? From what I've read, they seem like a solid option for mail-order.
Old Oct 24, 2023 | 05:38 PM
slothman's Avatar
what ? dude, Kali has some of the best tuners in the nation. it would be VERY easy to find a tuner, and well worth your travels. If you are super far north or something.
mail order tunes are really not ideal. you need to get that thing on the dyno and have it tuned RIGHT
goto the Kali section and ask guys what tuner to go to that is closest to your home
Old Oct 24, 2023 | 06:26 PM
trever20's Avatar
I can't do a dyno tune any time soon as the swap vehicle is no where near being ready to be driven. I just need a baseline tune to be able to start and run the engine, then I will get a dyno tune eventually. I'm located in the Bay Area, which is extremely strict on emissions and smog. There are very few shops around me that do tuning, and since I can't drive the truck for a dyno tune, I see no reason to go with one of these tuners over a mail order tune from a reputable company. One shop near me wanted $1000 for a baseline tune, no dyno, which is absurd.
Old Oct 27, 2023 | 12:04 PM
gagliano7's Avatar
Check your oil to see if it is diluted with fuel. If not you should be fine.
