Need help with high idle on sd base tune
Try blocking the PCV into the intake manifold. If that works, you might then want to re-enable the IAC (and tune for it). Then setup a working PCV.
What is base spark timing in the idle cells ? Many tuners will crank in 22 or 24 degrees of idle advance out of habit; Yours might idle okay at 17 or 18 degrees.
Are there some wide swings in the spark map NEAR idle speeds ?
Confirm that the spark advance is same in the IDLE, Low octane and High octane maps.
