Using Hypertech and LS1 Edit at the same time?
I want to continue using the Hypertech for a while longer until I get real tuning but I will be installing headers and an LS6 intake soon and I also want to delete the codes via LS1 Edit from the shop doing the work.
My question is, can I have some codes/SES lights deleted via LS1 Edit and STILL use my Hypertech for the other desired adjustments?
Will the PCM be able to recognize both provided that they are altering separate parameters?
Thanks in advance.
I do agree that you should sell the HPP3 and move on to a real programming tool. You'll love having more control over your A4 that comes with Edit or HP Tuners
I would only be having the shop delete codes for DMV inspection reasons (and because I don't want to stare at dash lights constantly
) but still wanted to retain the ability to make my own adjustments at the track without having to rely on anyone else for changes constantly. But if the two won't 'get along' with each other than I can't utilize both at the same time of course.Maybe I'll just get my headers/intake installed, run the car as is and then get the codes deleted along with the shift points/fan settings all at the same time later on and just sell the HPP.
,butHPP3 is NOT Compatible with LS1 Edit Tuning,I know this First hand.I had my Car Dyno Tuned for the first time last year and I couldnt even change my shift points on my 99
.I called HyperTech and they told me what I have already learned on my own.So I had tuner change the shift points and sold the HPP3...just my .02 I had a shop tuned PCM (not Ed Wrong) a couple years ago and it worked with HPP3 when i changed shift points. Must have been a different software that they used.
...thanks fellas.
Is it possible that the shop locked your PCM via Edit, and therefore prohibiting you access to make any changes ?
