Reducing fuel smell in tune
I have read that EOIT (end of injection timing) can be played with to prevent raw fuel going out the tailpipe. Any other tips on tune tweaks to make it more enjoyable? Unfortunately the car is stored for the winter so I don't have access to be able to post the tune.
Setup:
Gen 3 6.0, bone stock other than Sloppy Stage 2 cam, Specs: 228/230 .585"/.585" 112 LSA
Fuel: 93 and pump ethanol (E30 up to E70) depending on availability
Injectors: Siemens Deka 80s
Exhaust: 3" downpipe, Flowmaster 3" 3-way catalytic converter (FLO-2000130)
ECU: Terminator X, self tuned on the street
I welded in the cat hoping it would knock down the smell but unfortunately it seems to have made no difference.
PFA
I bet the catalytic converter is not "lighting off" since it's understandably a good ways behind a turbo. How far downstream is it? Is the plumbing of the wastegate back into the down pipe or open?
Very cool ride btw!
Similar problem with "STINKY EXHAUST" on daily driver Suburban, even went as far as weld in High Flow CAT just after Down-pipe.
I have been told that RETARDING the spark at idle, and cruise can HEAT th cat and make it more efficient, but I like the throttle response I get from spark ADVANCE.
Let me know, keep us posted on the exact changes you attempt with EOIT.
My reading on the subject just confuses me more. the actual settings seem counter intuitive- HPTuners rendition of GM's oem line codes are less than transparent.
Very cool ride btw!
Setup:
PFA
https://forums.holley.com/forum/holl...e-tuning/page7
