LS3 will not run
Old May 7, 2026 | 12:11 PM
LSharold's Avatar
Default LS3 will not run
I have an LS3 engine that has been running perfectly until now. Suddenly, it dies 2–3 seconds after starting. Could it be that VATS has been activated? I’ve done some electrical work, but nothing involving programming. Could it be a grounding issue? (I can't find anything obviously wrong) Thanks for any help, Harold
Old May 7, 2026 | 12:27 PM
Kubs's Avatar
Gonna need a bit more information here bud.
What car is it in?
Does it turn over?
Does it have fuel pressure?
Etc
Old May 7, 2026 | 12:32 PM
LSharold's Avatar
Its in a Corvette C3, and yes, have fuel pressure and it turn over
Old May 7, 2026 | 03:40 PM
LS1 TJ's Avatar
Crank sensor toast? The ECM wants to see crank rotation.
Old May 7, 2026 | 06:37 PM
SyncPil's Avatar
That really does sound like VATS/security kicking in, classic “starts then dies” symptom. Since you recently did electrical work, I’d double-check grounds and ECU/ignition connectors first.
Old May 8, 2026 | 12:41 AM
LSharold's Avatar
Thanks, I will check thise
Old May 8, 2026 | 07:35 AM
pcguy's Avatar
Electric fuel pump? Power from a relay? Test the relay power when the engine dies. If you have a later model fuse box with a bunch of relays, swap the fuel pump relay with one of the others of the same type...
Nick
Old May 8, 2026 | 08:59 AM
LSharold's Avatar
Thanks pcguy, I'll give this a try. (I can hear the fuel pump priming when I turn on the ignition.)
Old May 8, 2026 | 08:04 PM
B52bombardier1's Avatar
What is your fuel pressure at the rails before and after engine start?
Rick
Old May 9, 2026 | 01:32 AM
LSharold's Avatar
I havent check the fuel pressure yet, will do
Old May 9, 2026 | 01:34 AM
LSharold's Avatar
Just to specify the problem a bit more accurately: the engine starts every time I try, but it dies again after about 2 seconds. This happens over and over again.
Harold
Old May 9, 2026 | 06:32 AM
What is your fuel pressure at the rails AFTER this happens? My guess is your electrical work noted above now stops your fuel pump.
Rick
Old May 11, 2026 | 05:55 AM
LSharold's Avatar
I’ve checked the fuel pressure now, and it’s fine both before and after the engine stalls. The engine starts, runs for about two seconds, and then dies. I haven’t made any changes to the ECU, so I'm assuming it's not an VATS issue?(I have double-check grounds and ECU/ignition connectors)
Any ideas what the issue could be? Thanks in advance
Regards
Harold
Old May 11, 2026 | 06:27 AM
Tommy42088's Avatar
Did the problem happen right after you worked on the car? Also you said you have done electrical work? What exactly did you do?
Old May 11, 2026 | 06:36 AM
LSharold's Avatar
I replaced the battery and tidied up the wiring under the dashboard. I've double-checked everything, and all the fuses are fine. I also measured the power from the ignition switch, and it stays on after starting.
Old May 11, 2026 | 10:20 AM
Tommy42088's Avatar
yikes, you sure you didnt pull anything loose under the dash board? Are you sure vats was deleted in the tune and not by a resistor under the dash and you maybe pulled it loose?
Old May 11, 2026 | 11:22 AM
LSharold's Avatar
Thanks for the tip! I didn't know a resistor was an option instead of ECU programming. I didn't swap the engine or build the car myself, so I’ll definitely have to check that. Thanks
Old May 11, 2026 | 11:47 AM
Tommy42088's Avatar
yeh id be checking those wires under the dash and make sure there isnt a resistor but connected in somewhere that you may have pulled out or cut loose when cleaning up the wiring.
Old May 11, 2026 | 11:53 AM
LSharold's Avatar
How can I know for sure if VATS is activated? Can I measure the injectors or check a spark plug to see if it stops sparking?Can I use a standard diagnostic tool to check if VATS is enabled?
Old May 11, 2026 | 12:15 PM
Tommy42088's Avatar
plug a noid light into the the injector connector. If vats is enabled it should kill injector pulse. You can do this with a test light too, one wire should be 12v and the other should be ground, the ground should be the wire that pulses as your trying to start. If ground doesn't pulse and cuts off instead then vats is enabled.
