Torque Managment, Yes or No
torque even at moderate load, meanwhile allowing
long shift times for you to notice it. Miniimize shift
time and you won't mind it so much; raise the torque
limit if you choose. I run a nominal 500lb-ft limit with
a modified trans torque management table and a
modified spark vs torque reduction table. Just to
cap off the really hard abuse, while having no TM
noticeable in normal sporty driving.
But you could always just take the axe to it.
More critical than TM is line pressure and accumulation time for the gear change.
accumulation time for the gear change?
Bill
aka ... different names in different tools but
it's the only thing with "time" in it.
This param is the "goal" for shift cycle time
total, that the PCM adjusts during-shift line
pressure to meet. You also have the during-shift
line pressure adjustment and I'm not sure how
these interact or overlap; the adaptation time
always has done the job for me.
I know SLP is a sponsor, but a lot of the stuff they say is wrong. The 4L60 has been around for years without TM. I've personally seen older non-TM setups last 200k in a truck application with plenty of heavy towing.
transmission. A little kindness at the right time
can go a long way, and you can make it not
cost you if you're smooth about it, is all I'm
saying.
I know SLP is a sponsor, but a lot of the stuff they say is wrong. The 4L60 has been around for years without TM. I've personally seen older non-TM setups last 200k in a truck application with plenty of heavy towing.accumulation time for the gear change?
Bill
Increasing the line pressure will increase shift firmness and reduce the shift adaption time - but only to the limits of the tranny accumulator. If indeed you are runnign max. line pressure and the shift is still taking too long, you can either introduce TO Management to retard some timing durign the shift and help it along OR put softer springs in your shift accumulator piston.
Cheers
