Question for guys with engine management Accel/Fast/BSIII
Old Aug 30, 2004 | 11:55 PM
JS's Avatar
JS
Default Question for guys with engine management Accel/Fast/BSIII
I'd like to know what options were lost when u installed a FAST/ACCEL or BSII into your car other than the dash (Gauges)
Did the lights still function,h/l motors go up and down,abs,heat etc.
I wanna install a BSIII with John M. harness into my car and at this point I dont care if I lose a few things.I can put a water/oil psi on my pillar,I dont need a tach (A4) speedo I can hook up via a conversion (truck style).I would like to keep heat and all lights,h/l function and signals...Does installing a stand a lone casue these things to go buh bye,I've only installed a piggy back type and that was in LT1 cars....
Anyone with a stand a lone please give me some info...
Old Aug 31, 2004 | 10:39 AM
JS's Avatar
JS
Anyone......
Old Aug 31, 2004 | 10:49 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have FAST bank/bank standalone:
-all lights work they are part of the body control harness not the engine control harness
-I lost ABS long ago when I did my 9", I have no idea
-I have heat
-I have a 98, I lost all the gauges except fuel level
-I am running aftermarket 5" tach off the FAST
-I am planning to make custom gauge cluster to run all aftermarket gauges
Old Aug 31, 2004 | 11:00 AM
-=Merlin=-'s Avatar
I was under the impression from what was posted about the BSIII that it was a direct plug and play, i.e. used the stock harness and sensors, system.
Does the harness have to be replaced?
Old Aug 31, 2004 | 11:12 AM
JS's Avatar
JS
Yes it is a plug and play but u will lose some functions.
I think John is correct,I will lose gauges,abs...
My H/L and heat and all controls will still work.
Then I'll need to figure out how to get my gauges back on line.
I dont think I'm gonna order a trans option.
I can set shift points via edit and once there done I wont need to do it anymore.
Thanks John....
Old Aug 31, 2004 | 12:59 PM
LS1Tech Co-Founder
You lose the gauges, you would need to wire them into the BS3. That is the case for all aftermarket pcm solutions.
Old Aug 31, 2004 | 01:13 PM
JS's Avatar
JS
So if I wire the gauges into the BS I will only lose the speedpo and poss the abs?
Old Aug 31, 2004 | 11:47 PM
TimeMachine's Avatar
The BS3 now interfaces to the RacePak UltraDash via a high speed CAN link and you can display 6 things on each screen. There are 4 screens. Currently I display MPH, engine rpm, AFR, TPS%, Fuel pressure and Spark advance on 1 screen. Trans gear, pan vacuum, TCC %DC, line pressure, and 2 others... I can't remember now are on screen 2. You can even program the dash for a shift light or warning light (i.e. low oil pressure). The dash has a built in record and playback feature also.
