Should I smell like I bathed in 93 octane after sitting still?
Old 08-31-2004, 03:29 AM
darknight's Avatar
Default Should I smell like I bathed in 93 octane after sitting still?
My car is spitting out unused fuel at idle(black mark in garage floor). I smell like I took a bath in 93 octane when I sit still and idle for more than 2 seconds. Is this normal for h/c cars without cats?
Old 08-31-2004, 03:54 AM
OnyxY2KSS's Avatar
this happens to me at a light with the windows down, but i think i have an exhaust leak
Old 08-31-2004, 04:32 AM
John_D.'s Avatar
My car is running rich at idle too. I have a similar cam, MACS, 85mm maf too. Started a post on it earlier. Advice so far was possibly tune it out using VE. Not sure if that will work or not, closed loop will try to maintain o2 voltages where it thinks they ought to be.
Old 08-31-2004, 07:29 PM
Jorday's Avatar
my car is the same way
and to be honest with you I'm beginning to get pretty sick of it
Old 08-31-2004, 09:00 PM
wait4me's Avatar
i will set you guys all up just email me at jessebubb@yahoo.com no more stink, lots more power.
Old 09-01-2004, 12:42 AM
ram-it's Avatar
Modifying the VE table between 400-1200 rpms solved the problem for me plus I picked up a little power at the strip and cured surging issues on hot starts. That was the first thing I learned and played with when I got HPT. Since I have modified my IFR's, PE and Spark. All this netted me a 3mph increase at the track from one tune to the other. AND no gas me out of the garage smell either.
Old 09-01-2004, 12:51 AM
horist's Avatar
my car used to reak of gas... and spit out black **** everywhere at idle... then I tuned it you're running rich .. a large cam isn't very efficient at lower RPMs ... just need to do some LTFT tuning
Old 09-01-2004, 01:20 AM
Jorday's Avatar
I've tried everything in the book, and it does help. It still stinks a little, though.
Old 09-02-2004, 04:44 AM
darknight's Avatar
Cool guys! Thanks for the knowledge. I will either have the tuner work on this or have wait4me hook it up. My woman doesn't even like to ride in the car now. If that is good or bad, I am not sure.
Old 09-02-2004, 09:02 PM
John_D.'s Avatar
I think this table might be the place to fix it. I'll be experimenting this weekend.
Fuel Control,
Open and Closed Loop Fueling,
O2 Rich/Lean vs. Airflow
These are the stock values (voltages):
366, 436, 436, 436, 457, 491, 501, 457, 457
Those are for airflow values:
0, 2, 4, 6, 8, 10, 12, 14, 16
I believe the 0 and 2 columns are the ones that will impact idle a/f. The upper 5 values are all very near the .5 mark as expected. But the lower flow columns (and colder exhaust) drop significantly. Headers (with more cooling at idle due to the thin walls and more surface area, and with increased distance to the sensor) will report even less voltage at the correct a/f ratio.
Not sure yet how much to tweak them though.
Old 09-04-2004, 05:08 PM
samz28's Avatar
keep us updated on your find, i'd like to burn leaner at idle. I already did the VE tables but the LTFT's are not all that happy with the results at idle
Old 09-05-2004, 01:35 AM
bomax's Avatar
I have heard of using TPStoWOT to zero for 400-1200 then using VE table to adjust the idle. This forced the car into open loop at idle.
Old 09-05-2004, 08:40 AM
samz28's Avatar
does the car still adjust air fuel properly with the MAF in this mode? You then assume the MAF is correct and cannot foul or get dirty right?
Old 09-07-2004, 11:37 AM
99C5JA's Avatar
I'm having some similar issues. The car smells very rich at idle. Also warm or cold the idle will hunt badly for a minute or so then smooth right out. Another thing I've noticed is that the engine seems to run smoother above 3k. It's almost like you've flipped a switch. I've heard that the LS1 doesn't switch completely to mass air until about then, could this be what I'm noticing? If so is the VE table what I should be looking at (in HPTuners I'm guessing that this is Primary VE vs. RPM vs. MAP)? Which way would you modify the values?
Old 09-07-2004, 12:05 PM
samz28's Avatar
based on the default values for the stock tune, search for nogo's guide on VE tweaking.
i did something like .7/400 .8/800 .9/1200 on my TUNED tune, on both ve's and then did .9 on the cranking VE and added some timing from 400-1200rpm and the car smells better but without cats you'll always smell some ***. The surging shouldn't happen.
you need to make sure your maf(clean)/o2's good and then run a log/histogram on the ltrims to see how far badly the tune is off at part throttle.
