missfire driving me nuts!
the car missfires under any load and slightly while idling, ses flashes when cruising (random multiple missfires code).
here's some history of the problem, it started with a single miss every 10 or so minutes apart while in 6th under load. then the misses started getting worse thorough out the day untill it reached the condition above. it almost felt like a broken valvespring ( cause it happened om my car before).
we hooked the car to the scanner and it showed # 5 missfiring , so we change all the plugs to be safe and try again, now 1, 4,5 are missing.
so to keep it short here is what we did:
-swapped plug wires
-used a different coil and moved it to several locations
-did a compression check
- leak down test
- pulled valve covers and checked for broken springs
- pulled pushrods and checked for straightness
all had no result on the miss.
what can it be?
could it be a bad crank positioin sensor? cam sensor?
for some reason i keep thinking it could be that the reluctor wheel on the crank loosened up ( he just put in a new eagle crank), could that be the problem?
is there any way to check that?
-swapped plug wires
- leak down test
what can it be?
GAH! i don't either! my car is doing almost the same thing and it's killing me.
Mine sputters at anything above 1/4 throttle.
If i put it in drive and hold the brake and hit the throttle it does fine up till it gets to 1,400rpm, then at 1,500rpm it sputters, sort of sounds like a ghetto rev-limmter.
I was told it might be a bum MAF. Haven't been able to take it any where to see what code it's throwing. (short on cash)
For your car I'd say it's probably a crank/cam sensor if it's running that bad.
I don't know about checking it though. I'm just now learning the fancy heavy stuff my self trying to figure out why my car is being a heap.
well, i doubt i was any help but hey! your not alone! lol
Good luck.
its not my car thats doing it, its an acuantance of mine who broght it to me to fix it.
i told him to get a cam and crank sensors and see what happenes from there.
Misfires are generally caused by plugs, plug wires, and injectors very seldom its something else.
2 possible things here that i have been through. one on a friends car he had a pushrod SNAP.. yeah not bend snap and that obviously caused it.. then check you plug wires.. start your car somewhere with it pitch black and see if you see one of them arcing.. also check your plugs.. do the cheap **** first before you assume bad
black transam , i already pulled the pushrods out and checked them and the springs.
plugs are new and so are the wires ( i also tried using a different set just to make sure)
If you guys manage to figure out what's going on please post it!
My car is pretty much useless and it's my only form of transportation.
Time to pump up the tires on that 12yr old Christmas mountain bike.
